Poly and Zoom Rooms | Community
Poly and Zoom Rooms
  • December 10, 2025
  • 1 view
Is it possible to use two poly bars for one Zoom room? I know you can use this with Huddly cameras, but using two poly bars in the same space would be amazing. I tried reaching out to HP, and they said it is possible, but it was not a confident response.
bstrelko
Specifics matter - what are you actually trying to do?
For audio? Absolutely not.
For video, yes - depending on what you're trying to do. The 'bars' (please specify exact model so we're on the same page) will not auto-switch (I assume you're referring to Huddly crew, which can do this with 3-5 cameras).
You can absolutely configure 2 'bars' (Studio X30, X50, X70, X32, X52, X72) with one as the primary Zoom room and one as a "Companion Zoom Room", but this will effectively add a second camera and set of video outputs, not much else.
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0057777
Certain Poly cameras - not 'bars' - can be configured to run Zoom's Intelligent Director multi-cam mode, a terrible implementation of multi-cam that was teased for several years before its lackluster release. Cripples optical-zoom PTZ cameras into static digital-zooming garbage with all cameras coming from only a single direction. Needless to say, I don't recommend this option.
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0057795
