Zoom phone number change
Hello community,
I'm new to the Zoom Phone (registered today) already have got an issue 🙂
How can I change Zoom Phone number? I've got US number instead of Canadian (which I need) and now need to change it.
Regards,
Muza
Hello community,
Regards,
Muza
Hi MuzaS,
Please check to see if your usa number is assigned to your main auto receptionist. Your Profile->admin-> phone system management -> auto receptionists -> profile. If your usa number is assigned to the main auto receptionist, click unbind.
If your usa number was not assigned to the auto receptionist, then it was probably assigned to you as a user. Go to Your Profile->admin-> phone system management -> users & rooms ->profile -> numbers. Click Remove to remove your usa number from your user profile. Your number should end up in unassigned numbers.
Go to Your Profile->admin-> phone system management -> phone numbers -> unassigned. Click your usa number and click delete. This will free up a number license for your Canadian number.
After removing your usa number, you can now choose a Canadian number.
thanks, eliot
