Setting Outbound Caller ID doesn't have anything set by default | Community
  • October 18, 2022
  • 3 replies
  • 18 views
I'm trying to set Outbound Caller ID for our new Zoom Phone account.
Firstly, why is there no default setting for all accounts to use one number, I can't seem to find anything. Anyone who doesn't have Outbound Called ID set cannot make outbound calls.
Secondly, when I got into each user and look at the Outbound Caller ID dropdown, there is nothing I can select. In our Phone Numbers section there is the initial number we got on Zoom Phone sign up, and 2 pending numbers which are porting in. the initial Zoom Phone number is working fine. To set the Outbound Caller ID, I have to add it in as a Custom number. Then after that the  Outbound Caller ID dropdown is populated and I can now select that number, and then remove the custom number. seems too round about. Where do I set the dropdown selection?
    Best answer by Eliot
    please see attached screen shots for company info->account settings->outbound caller id.
    to select which caller id you want to display on outgoing calls, use the drop down on the dial pad.  the drop down is available on desktop clients and mobile clients.  please see attached screen shots.
    as admin, you can limit what users can select as caller id.   happy to provide details.
    thanks
    eliot
    Contributor I
    October 18, 2022
    Hmm, for ours the default main number set in the default site in the Company Info settings get set by default for common area phones and possibly for user extensions in some cases when they do not have their own DIDs.
    Hmm been a while since I've looked at this, I think the DID used is the DID assigned to the default auto attendant for the default site in the Company Info page.
    October 18, 2022
    please see caller id support articles
    Managing the main company number and caller ID – Zoom Support
    Frequently asked questions about caller ID – Zoom Support
    the outbound caller id is the first telephone number listed on your Main Auto Receptionist
    Profile.
    as explained in the support articles above, admins can control what caller id's users can display.
    if permitted by admin settings, users can select what caller id number is used for outgoing calls such as main company number, a call queue number, and their own direct telephone number.
    thanks
    eliot
    DamienGMAuthor
    Hi, reading the first link, there is no CallerID field in Company Info->Account Settings: Settings (we are not multisite). Its not because we are in Australia? We also have a normal number and toll free number.  I've assigned both numbers to the main auto receptionist, but that doesn't seem to have worked either.
    EliotAnswer
    October 19, 2022
    thanks
    eliot
    October 20, 2022
    hi damien,
    thanks
    eliot
