Contributor I
February 23, 2022
Seems so simple - urrrrh! why do incoming calls 'ring' in Queue when we are all logged out?
Hi!
We are new to zoom phone.
The 'call queue' phones ring for the allocated time eg 45 seconds - despite all users being logged out.
Is this how the system is supposed to work? Or does this mean that someone has accidentally still logged in from eg. home?
I thought that calls go to 'overflow' (Eg voicemail) if all users are logged out, but it doesn't seem to work like that.
Thank you very much for any comments greatly appreciated.
Richard
    NRidge
    NRidgeAnswer
    Firstly, we are sorry to hear about your frustration and wish to help!
    A few questions:
    1) Are you primarily relying on Zoom Client (Software on Desktop, Mobile, etc), and/or are you also using hardware phones (EG: Poly, Yealink, etc)?
    2) How are users logging out?  Are they logging out of the hardware phone? Zoom Client only?
    3) Have custom call queue business hours been set and are calls rolling to your after-hours action appropriately?
    4) How are you validating all users are logged out of the call queue?
    My first thought is that for a user that logs out on the hardware phone and client, it might be that the user logs out of the App but not the hardware phone (or the other way around, logging out the phone, not the app).
    My second thought is maybe make sure that when users are all logged out from app and hardware phones, ensure the routing action for the queue is set to the appropriate action.  (Note call queue's "during business hours" overflow action is separate from the After Hours routing option.)
    Resolution options:
    A) "Sign me out from all devices" via web: User can select the "Sign me out from all devices" option in the user profile (Web option):   To use this option, navigate to their web profile, (Personal >> Profile >> Sign in section, and select the text "Sign me out from all devices" which is a hyperlink to this action. (User will need to sign these devices back in at next start of shift)
    B) Sign out - Granular steps: Ensure user logs out of the phone and app instances (Desktop, Mobile, etc).
    C) If the user is simply taking a break period (lunch, etc.) and does not want to sign out of the app/phone, there is an option for the user to Opt out of call queue.  This is found under Personal >>Phone >> Settings tab as shown below:
    If this helps please let us know which option solved it!
    If this solves your question please be sure to mark as a solution and like!
    toddcarswell
    Richard,
    Do you have physical desk phones registered to Zoom that are included in the queues? If a user is configured for a call queue and they log out of their client, the system will ring their phone because it appears that the user is logged in.
    Also, before they log out of the client, can you have your agents toggle the checkbox to remove themselves from the  Call Queue? They need to click on their profile pic at the top right, then look at the call queue section and remove themselves from the queue. Here's a screenshot for reference:
    Please click "Accept as Solution" if this addresses your issue. Thanks!
    NRidge
    NRidgeAnswer
    A few questions:
    Resolution options:
    RichardB1Author
    Contributor I
    March 4, 2022
    After many days of testing, I can confirm the ONLY solution is for all users to un-toggle call queues.
    If you make ALL users as 'not available' then the ringtone sounds once or twice isn't too bad.
    However, if users are set quickly as 'away' (the grey dot appears, rather than the green dot meaning available) then the phones continue to ring. I think this is a little glitch that needs resolving.
    NRidge
    @RichardB1
    How many queues does a user a member belong to? Are you saying they are taking a break and need to toggle all queues to "opt out" state, or are we looking at a different toggle?
    If you think we need a better option, what would you suggest that could make this a better workflow?
    Thanks in advance for your feedback!
    RichardB1Author
    Contributor I
    March 5, 2022
    3 members each 2 queues
    yes, toggle out of Call queues when taking a break
    Best option is logging out has same effect.
    OR
    away status same effect.
    if all users set as away AND/OR all log out, the caller still gets ring tones which makes no sense.
    why?
    because user has to remember to toggle to accept call queues the next day.
    NRidge
    @RichardB1
    Thanks for the additional feedback.  For your last two comments:
    1) "if all users set as away AND/OR all log out, the caller still gets ring tones which makes no sense."
    I'd agree if all users in a queue are unavailable (Status Away/Do not disturb and/or logged out) the expectation would be to use the overflow action.  I can look into this and see if I can reproduce it, could be a bug or just something we could improve.
    2) "why? because user has to remember to toggle to accept call queues the next day."
    --I'm not sure how you get around the user opting into the queue if they are allowed to also opt out. Users may have different shifts or days off and automatically making a user available to a queue could be problematic for other reasons.  Shouldn't this be part of user training to be logged in and available for a queue?
