Paying Credit for Calls to mobile numbers | Community
  • March 8, 2025
  • 0 views
I would like to find out if I can make calls to mobile numbers and landlines using Zoom and if so what are the subscription option.
Best answer by Eliot
hi @mupfanochiyat
you can make calls to mobile numbers and landlines using zoom.
depending on where you are calling from, there are metered plans, unlimited regional calling, and global calling plans.
please see Plans & Pricing for Zoom Workplace | Zoom
EliotAnswer
March 10, 2025
hi @mupfanochiyat
Dear Elliot
Thank you very much for taking your time to address my question. Your suggestion worked . Thank you once again.
