how to get direct calls without putting the extension number? | Community
  • January 15, 2023
  • 0 views
I just got started with Zoom phone, and I've noticed that the callers need to put an extension number that I chose to make the call.
how can I disable it? and just get a regular direct call?
TY.
    FORE-Craig
    Specialist
    Specialist
    January 15, 2023
    Hi @levyx10
    The easiest thing to do is to go to Admin > Phone System Management > Auto Receptionist in the Zoom web portal at https://zoom.us/profile, choose the Auto Receptionist and in the Business Hours section:
    • Set the Business Hours to 24/7
    • Set Greeting Prompt to Disable
    • Set Route to User, and select your Name from the drop-down menu presented
    From that point on anyone calling the number will go directly to you.
    You should also go Personal > Phone > Settings, and configure the entire Call Handling section there.
    I hope that helps!
    Thanks @FORE-Craig! I had the same question.
    That just helped me today, thanks sharing, appreciate the effort.
