fix zero-touch provisioning of desk phones | Community
  • September 7, 2021
  • 2 views
How can I fix zero-touch provisioning on our hundreds of new-in-box vvx250 polycom phones?
Some auto-provision on first boot, as advertised.
Some fail and must be factory reset.  After the factory reset some will auto-provision correctly.
Many require assisted provisioning.  This requires us to log into the phone's web page and manually enter the provisioning URL, clear out the username/pass, and set DHCP to static.
My goal is to avoid assisted provisioning.  Is there a way to take the config of a phone and quickly flash it to another phone?  Can we do that in bulk?
    @JoshT ,
    Good day!  I hope you are well.
    As you indicated, Zero Touch Provisioning (ZTP) will be the best way to provisioning all of your Poly handsets.
    I would recommend opening a support ticket on one or two of the handsets that are failing the ZTP process which is requiring you to step through the assisted provisioning process.  It would be best to make sure the root cause of the issue is understood.
    There may be another viable option for you if all of your devices share the same manufacturer and if you have control of the DHCP server.
    Zoom has a single URL per manufacturer which would eliminate the need for the assisted provisioning and bypass the ZTP process that appears to be failing for you.
    The URLs are as follows:
    AudioCodes - https://provpp.zoom.us/api/v2/pbx/provisioning/audiocodes
    Poly - https://provpp.zoom.us/api/v2/pbx/provisioning/polycom
    Yealink - https://provyp.zoom.us/api/v2/pbx/provisioning/yealink
    This info was pulled from here: https://support.zoom.us/hc/en-us/articles/360033223411#h_01F65FEPTABPHZERDMF84NBET6
    Keep in mind, using one of the above URLs is only supported by the corresponding manufacturer, which is why it would be best to ensure ZTP is working properly.  Not all devices are supported with this method, though the VVX-250 certainly should be.
    If you have a ticket, feel free to direct message me with the number and I'll see if I can assist.
    Does Zoom have any document explaining how to configure DHCP options for Poly VVX-series phones to force registration to https://provpp.zoom.us/api/v2/pbx/provisioning/polycom ?
    3 years later and Zero touch still doesn't work, I get about 2 out of 5 actually work rest need lots of touching. Did you ever find DHCP options?
    Scheived,
    There are many factors in play with Poly handsets when it comes to ZTP.  Here are a few items that may be worth a look:
    • DNS - if the device isn't getting DNS from the DHCP server, it won't be able to "find" the provisioning servers.
    • NTP - if the date on the phone is way off, this could result in a failed attempt to reach provisioning servers as the devices won't "trust" the certificates in the provisioning process.  Verify the NTP server is accessible from the device.
    • Firewall - As Eliot alluded to, there are a number of ports/IPs that required for ZTP, not only from Poly, but Zoom as well.
    • PCAP - it would be a great step to grab a packet capture of the traffic as you could identify where the breakdown is in conjunction with the device logs.
    • DHCP Options - 66 and 161 may be used.  Using these options is not supported by Zoom.
    I hope this helps.
    If you go the PCAP route, feel free to post it here and we may be able to offer some insight.
    Warm Regards,
    Aaron
    September 30, 2021
    hi josh
    one of my clients had a similar issues.
    for ztp, poly phones need to connect to poly.   check that the phones have access whatever subnet they may on.  in one case ztp at one location worked but not at another.   the issue was solved with a change to access control list.
    Required Ports and Trusted IP Addresses and Hosts (polycom.com)
    in real time, zoom connects to poly to provide the mac addresses that a zoom phone admin enters.  the mac addresses are hex addresses containing 0-9 and a-f.  you should not do a copy and paste of the mac because what you copy may contain special characters.  you should manually enter the mac addresses.
    Managing phones and devices – Zoom Help Center
    best
    eliot
