Default Voicemail Heard Instead of Call Queue Voicemail When Transferring Directly To Voicemail | Community
  • March 9, 2022
  • 10 replies
  • 9 views
We have a call queue setup with an associated call queue voicemail audio file.
If we try to transfer a caller directly to the call queue voicemail, we encounter the system default voicemail (I can tell it is system default based upon the voice and scripting). I would've expected it to go to the call queue voicemail that we've setup.
To add to the confusion, if a voicemail is left, it does show up under the call queue. The issue is that we need the voicemail they encounter to be the same one that is associated to the call queue and cannot figure out how to solve this.
Does anybody know?
    IP-Man
    @kmateze , if you are transferring from an IVR or AR(Auto Receptionist), the you need to specify the voicemail greeting to be used else it will use the system default greeting.
    If my reply solved your discussion don’t forget to mark reply as the solution. Thanks!
    If this answer helped solve your question/issue, please hit the -Accept as Solution- button below.
    FORE-Craig
    Specialist
    Specialist
    March 10, 2022
    Hi KMateze,
    We 've never had the need to forward a call to a Call Queue's voicemail directly, however, I can understand the business case for doing it. I tested it with our setup, and can confirm that it did indeed play the default voicemail greeting, and not the customized greeting set up for Business Hours on the Call Queue, which does indeed play when a call is not answered.
    I would suggest that you log a problem with Zoom Support at https://support.zoom.us/hc/en-us/requests/new
    @kmateze Kindly check on the call queue Overflow routing during business hours and closed hours which I'm assuming that it is set to Leave Voicemail to Current Extension. If it is, click on Edit then check that Voicemail Greeting is not set to Default. If it is set to Default, hit on Audio Library and select the custom audio you have recorded then click on Use the Audio then Save.
    With regards to Call Queue voicemail, using the Zoom App, user can tell if a voicemail received was for the Call Queue by clicking on the Voicemail tab. The voicemail will have a text label like "For Call Queue Name." From a deskphone, there is no way to tell if a voicemail received is for a Call Queue or for user's direct number.
    If this answers your question, please mark this as "Accept as Solution" or you may provide more feedback for us to understand more your issue.
    FORE-Craig
    Specialist
    Specialist
    March 10, 2022
    Hello @zac2021,
    Perhaps you didn't read my reply that I posted prior to yours. I have tested the scenario outlined by @kmateze on our system, and experienced the same results of the default voicemail greeting playing as opposed to the customized overflow greeting which is set on our Call Queue. There is a apparently a bug.
    Hi @FORE-Craig ops, sorry for that one. Would you mind sharing a screenshot of your call queue please. Something similar below.
    If it is a bug, we will be more than happy to log a ticket for that.
    Thanks
    FORE-Craig
    Specialist
    Specialist
    March 10, 2022
    Hi Zac,
    Here is a screenshot of the Call Queue that I tested with.
    Thank you!
    @FORE-Craig Thank you for sharing a snapshot of your call queue. Config appears appears to be correct. Please submit a support ticket here if you have not done yet or we can assist you also to log a new one.
    FORE-Craig
    Specialist
    Specialist
    March 10, 2022
    I haven't already done so; I was just testing to validate what @kmateze was experiencing, since we generally don't transfer directly our Call Queue's voicemail. I will do so though. Thanks!
    kmatezeAuthor
    Hi! Thanks @FORE-Craig  and @zac2021 . For continuity I have also included my screenshots to demonstrate that my config appears to be correct and yet experiencing the behavior earlier stated. I will also open a support ticket.
    @FORE-Craig @kmateze would you mind to please share your ticket reference number. Curious to see what the issue is. Thanks
    kmatezeAuthor
    #13779245.
    @kmateze Thanks for sharing the ticket#. What's the call queue extension having the issue?
    @kmateze,
    Good day. I have also tested this in my lab, and I find the same results. The default greeting is playing, and I could play the voicemail in the call queue.
    The VM greeting of the call queue can be different depending on where the call originated. E.g., the AR is transferring the call to CQ VM, the VM greeting it will be playing will be the one we set up in AR and not in the call queue.
    A good example would be the workaround below that you might want to try while our support team checks the issue.
    I created an AR that will be an extension that the user will be dialing if they want to transfer to the VM of the CQ. We need to put the actual VM greeting we wanted to play. In this setup, the user who initiated the transfer should do a "Blind Transfer" to the AR instead of "Transfer to Voicemail."
    The direct transfer to CQ voicemail bypasses the VM greeting set up on the CQ, just like the AR transferring the call to CQ VM in the above workaround.
    I hope this helps.
    kmatezeAuthor
    Thanks @HuckFinn-ZP for the info! I just want to share that my current configuration if you do a blind transfer the call queue voice-mail is actually encountered. It is only if you do the direct transfer to voice-mail. Additionally, if you do a warm transfer and nobody picks up, the internal user doing the transfer  will hear the call queue voice-mail but if you decide to click complete transfer the caller will get the default voice-mail. Just wanted to share!
    kmatezeAuthor
    Typing on my phone, my sentence is unclear above. If you do direct transfer to voice-mail user gets default voice-mail instead of call queue voice-mail.
    Hi @kmateze,
     You have some responses to your discussion worth noting. Have any of these answer your question? If so, don’t forget to mark the reply as an accepted solution!
    kmatezeAuthor
    Thanks @HuckFinn-ZP . I was thinking I would update this group before resolving this ticket as they are Zoom support team is still working on it?
    Hi @kmateze We believe that we don't need to keep this item open. A feature request has been submitted already for this one for our product team to review. It may take time on when that feature would be available but you can always follow-up with our support team using the ticket reference # you had.
    If my reply helped, don't forget to click the accept as solution button! ⤵️
    @kmateze , I am about to say the same as what @zac2021 mentioned. The feature request is the best next step for this. You might want to consider applying the workaround I mentioned above while waiting for the feature request update.
    Hope this helps.
