Call queue outbound calls are not recorded | Community
Partner
February 8, 2023
  • February 8, 2023
  • 3 replies
  • 15 views
When a member of a call queue makes an outbound call is not automatically recorded even though it is enabled in call queue Policy Setiings.
Basically, we need all calls towards external numbers to be recorded, but when the user makes internal calls not to be recorded
thanks,
    Best answer by FORE-Craig
    Alex changed the Outbound Caller ID of the Users to that of the Call Queue.
    FORE-Craig
    Specialist
    Specialist
    February 8, 2023
    Hi @Alex_z
    I'm wondering if perhaps their Outbound Caller ID is not set to that of the Call Queue, perhaps it is set to their direct phone number, or that of the Auto Receptionist.
    I hope that helps!
    Alex_zAuthor
    Partner
    February 9, 2023
    Hi, thank you for your response.
    I have changed the Caller ID to Queue ID but nothing changed. The only way to record outbound calls is by enabling call recording in the user level. But this means that all calls will be recorded, even the calls to internal extensions .
    Any advice is very welcome.
    thanks,
    Alex
    FORE-Craig
    Specialist
    Specialist
    February 10, 2023
    Hi @Alex_z
    I understand your concern about enabling call recording at the user-level. I would submit a support request at https://support.zoom.us/hc/en-us/requests/new .
    There is definitely a bug of some sort. This support article clearly states that the policy applies to inbound and outbound calls - See attached.
    I hope that helps!
    Contributor I
    February 10, 2023
    I'm wondering if it only records outbound calls if the call is an inbound call to the call queue that gets transferred elsewhere?
    Since the call queue does not show up as a separate line key on agent's phone/app, outbound calls from an agent have nothing to indicate is a call queue call.
    FORE-Craig
    Specialist
    Specialist
    February 10, 2023
    Contributor I
    February 10, 2023
    Yep, but that is only setting the caller-id to match that of the call queue (and only for calls to the PSTN, not outbound internal calls).  I haven't seen anything that indicates changing the caller-id causes the call to be treated as originating from the call queue instead of the user's extension but have not done much investigation on this. So I could be wrong. But that would mean that only calls to the PSTN would be considered outbound call queue calls and not outbound calls to internal numbers!
    Alex_zAuthor
    Partner
    February 13, 2023
    Dear team,
    Thank you all for your replies. I really appreciate it.
    I found the reason for the issue.
    All incoming calls are routed to the Auto Receptionist and then to the Main IVR select the department by pressing the relative key.
    Afterward, the call is routed to the specific call queue.
    The client wants all outbound calls to have the AR’s caller ID so all incoming calls can be routed to the Main IVR.
    So, when the agent makes outbound calls are not recorded because they get the caller id of the Auto Receptionist.
    Is it possible to make outbound calls with the caller id of the Auto Receptionist but also to be able to be recorded?
    Thank you for your opinions
    Alex
    Exactly my question, too! Was there every a response? Our staff, part of the call queue or not, want the outgoing caller ID to read as our business main phone number. We understand that and it's all set. However, the call is not being recorded unless the user changes their caller ID to their own direct line number. Everywhere I can, I've enabled record and transcribe all inbound and outbound calls. We are on day three with Zoom and I am pulling out my hair!
