Zoom Workplace older versions - links to downloads | Community
Community Champion | Partner
March 31, 2025
  • March 31, 2025
  • 4 replies
  • 3836 views
Hi everyone
There were some recent discussions about links to previous, older versions of Zoom Workplace client.
If you know how those links are built, you can "make" them yourself (based on release notes page). But some people need a quick and easy solution. So I thought that I'll make a list for you with some recent versions.
Those are direct links to Zoom download site, so there is no need to worry about downloading it from a "middle-man" website and potentially getting a virus as a "bonus"..
Please also remember, that Zoom also has "Software Quarterly Lifecycle Policy", which enforces you to use client version newer than XXX provided in article linked below:
Zoom Software Quarterly Lifecycle Policy
So, here are links to some older versions. I've decided to provide links to 3 latest releases for version 6.5 and only the latest ones for lower releases 6.4-5.17.
Those links are only for Windows and MacOS. I've decided to skip Linux distros since it's a pain doing the same for some many distros... 😅
Version 6.5.1
Version 6.5.0
Version 6.4.12
Version 6.3.11
Version 6.2.11
Version 6.1.11
Version 6.0.11
Version 5.17.5
The previous msi installers all download the latest version?
LK_EXNAuthor
April 25, 2025
Do you mean those not included on my list?
If yes, then - no. You can find earlier version just by changing version number in URL. You can find those numbers here:
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0061222
Actually, I think the issue is in the post above, the clickable links are all going to the same URL instead of what the TEXT link says.  The visible text URL is correct, not the underlying link.
LK_EXNAuthor
June 25, 2025
Reserved
Anyone have 6.3.5 zoom room downgrade link and not the client?
LK_EXNAuthor
July 18, 2025
I can send you a link in PM if you want, but it's only for Windows installer. I wouldn't recommend doing it, unless you know what you are doing.
You can downgrade using Zoom Rooms admin panel, but only down to 6.4.2 version..
Here you have some more info on upgrade/downgrade possibilities.
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0067642
Although downgrade info for Android devices is not very accurate, since it can be downgraded as you can see on included screenshot. However there is caveat to that - you can downgrade ZR app on Android devices if they are not running the latest version, meaning there is "Update" button available. Otherwise - you won't be able to downgrade.
For Windows devices - it should be possible, however I have no way of checking that right now.
LK_EXNAuthor
July 24, 2025
Hi @enolen16 .
Drop me a private message as I cannot send one to you myself (maybe you have it disabled in settings??).
Which link is compatible with Android 11 OS?
LK_EXNAuthor
September 18, 2025
There is none. Zoom is providing link only to Google Play store.
Those links are only for Win/Mac machines.
