Zoom version history? | Community
  • September 7, 2021
  • 22 replies
  • 166 views
How can I see what Zoom versions I have had installed, that is, my version history?  Why?  Because I was involuntarily recently "upgraded" to 5.6.6.880 which when running caused my Windows 10 computer not to work well--a bad version for me.  I want to go back to a version when Zoom was working adequately, if that is even going to be possible--anyone?  If it is not possible to go back to a working version, then this question is moot.  Rather I will simply have to keep installing newer versions until one hopefully works well (well enough).  Please advise.
    Bort
    Hi @XB70
    Unfortunately, there is no report or tracking of which versions you have installed on your computer. If you would like to look at the list of previous windows versions and choose a specific version you'd like to rollback to, I can provide the download link for that specific version.
    Hi, can you provide me a link for the best/latest version for Win XP ServicePack3  32 bits ? Will I be able to use my current version 5.11.1 to connect to my WinXP computer (with the version provided) and do remote control access/support ? thanks
    hello I am having issues with the latest version of Mac zoom client
    can I get the download link to the previous version please? (December 27, 2021 version 5.9.1 (3506))
    Bort
    Here is a link to the official Zoom download of that version for macOS: https://zoom.us/client/5.9.1.3506/Zoom.pkg
    Do you happen to have the 5.9.1 version but that's compatible for the silicon chip? If so, do you mind sharing please.
    I am trying to find a zoom .msi for version 5.6.799
    I have a bad install or something and can't upgrade as the uninstall process can't locate the uninstaller files.
    I've had this before where if I can point it to a matching .msi file it will finish the uninstall process.
    I've opened tickets with Zoom via chat etc and no luck yet.
    I just need this version .msi file .. can you help?
    Thanks!
    FYI for anyone else having the issue where you need the old zoom .msi installer file to remove it, but can't get an older copy...
    I just used this Microsoft tool to remove it.
    Bort, I do not need this .msi  now!
    I had to run it 2x before it fully worked, but go with all default options when you run it.
    https://download.microsoft.com/download/7/E/9/7E9188C0-2511-4B01-8B4E-0A641EC2F600/MicrosoftProgram_Install_and_Uninstall.meta.diagcab
    Sunset9_4858
    I need to blur my background for a Zoom Meeting, but I don't have the old version of Zoom because in the videos they have the old version.
    Hi Bort,
    Is it possible to get Zoom Client 32 bit MSI for windows. the version required is 5.12.2.9281(5.12.2.9281_x86_tw59027-66132)
    Thanks in Advance.
    @Bort  Any update on this version?
    Bort
    Sorry about the delay. Must have slipped my mind. Here is the 32-bit MSI installer for 5.12.2: https://zoom.us/client/5.12.2.9281/ZoomInstallerFull.msi
    I am having an uninstall problem with the client and the plugin.
    May I please have the 64 bit zoom client msi v. 5.13.11835 and the msi for the Outlook plugin too?
    Zoom
    Zoom Outlook Plugin
    5.13.0
    Zoom
    Zoom(64bit)
    5.13.11835
    Hello Bort, I need 5.13.5 zoom outlook plugin
    Hi @Bort ,
    Any chance you are able to check my post from 2023-02-27 03:16 PM with the client computer and version 5.12.10196. Any solution with the Use Source file needed?
    Thanks!
    Eric
    Bort
    Here are the installers for 5.12.7 (10196):
    Hope that helps!
    Thanks @Bort ! Just seeing this. Appreciate you getting back to me and others on this page. Continue the great work! Kudos 🙂
    Hi @Bort ,
    Could you please give me the download link for version 5.11.3 for Ubuntu, 64bit?
    Thanks.
    Bort
    Hey, @Bort , any chance of getting the 64-bit MSI for 5.10.4420?  Have a user stuck on that version and can't uninstall without it.
    Bort
    Hi @cludena_svb
    Sure, here is the download link, but keep in mind you will need to immediately update to 5.11.4, as that is the current global minimum versionhttps://zoom.us/client/5.10.1.4420/ZoomInstaller.exe?archType=x64
    @Bort ,I'm so sorry, but I think I also need the MSI for 5.10.4 (5035).  The user's registry/Programs & Features was pointing to the older version, but this seems to be the one that runs.
    And no worries on updating, we're on 5.14.14578, it's just this one install I'm stuck on.
