Zoom recordings - changing how much is shown of the camera view
- November 13, 2021
- 6 replies
- 19 views
Dear All,
We use a Zoom Pro account for our church and record our services.
We use PowerPoint which is shared to those on Zoom.
That works well; however, what doesn't is the resulting recording: as you'll see in the attached screenshot, the PowerPoint slide is taking up 95% of the screen, and the camera view is a tiny % at the top right of the screen.
Is it possible to fix this? In an ideal world, I'd have the PPT slide and the camera view about the same size.
Having tried - and failed - with lots of tests, I'd be grateful for any suggestions. The simpler you can describe it, the better!
Many thanks in advance,
Patrick
