Zoom keep using my camera after the call has finished since an update a few weeks ago | Community
  • July 17, 2023
  • 6 replies
  • 3 views
Hi there,
Since an update a few weeks ago, Zoom keep using my camera after the call has finished (the blue light on my camera remains on and the "Zoom is using your camera" message is present in the taskbar).
If I try to make a second call the camera will fail to initialize in Zoom.
The only way to de-allocate the camera without a reboot is to go into task manager and kill all zoom processes, even after exiting Zoom.
Has anybody else come across something similar?
I'm using Window 10 and Zoom 5.15.3 (18551).
Hi TWA123,
Does reinstalling Zoom fix the issue? Are you able to revert back to a previous Zoom version that doesn't have that issue?
TWA123Author
HI Aaron
Re-installing unfortunately doesn't fix it. Neither did downgrading to 5.14.11.
Is this an internal webcam on a laptop, or an external webcam you have plugged into your computer?
TWA123Author
An external webcam.
Do you have the same issues with the internal webcam?
Try updating the webcam driver software on the webcam's website.
Actually, my HP computer's light is still on after my zoom session. It go away if I restart or close the computer and reopen it
I have the same issue. external camera, and after a call it stays on.
The only way to "off" the camera is going to zoom settings, select "Video and Effects", and close it.
October 30, 2025
First update to the latest version of Zoom (Version: 6.6.6 (19875)).
