Zoom cuts off at exactly 30 minutes | Community
  • August 18, 2021
  • 3 replies
  • 4 views
I am using basic Zoom for GSuite. My Zoom meetings should be 40 minutes (and it says so in the upper left-hand corner of the Zoom window. Zoom cuts off at exactly 30 minutes. I've complained of this to Zoom's technical support before, but they never addressed the problem (they kept telling me to get a different account).  I've wondered whether students joining the meeting before the host is counted at part of the 40 minutes. I have turned off "Allow participants to join the meeting before the host arrives" but I'm still getting messages students that students have joined the meeting room. Any ideas about what I can do?
    Best answer by Ajaneric
    While scheduling the meeting, did you set the time to 40 minutes?
    The meeting time is automatically set for 40 minutes. The problem was that I had allowed attendees to join before the host. When three attendees joined, it started the countdown. I turned that setting off. (Thanks to Bort, a technical writer for the Zoom desktop client, who investigated this issue for me.)
    Nafi
    Community Champion | Partner
    August 18, 2021
    Hi
    I suggest you to buy at least Pro license for this or maybe create another basic account can help to make it 40 minutes call.
    Actually if you are education institution you capable to buy zoom edu plan with cheaper price even compare to pro license with minimum qty 20.
    Hope it helps! please like and mark this as solution so whenever someone has the same question this content will help.
    AjanericAuthor
    Thanks for your ad but the issue is not the plan. The problem is that meetings are supposed to be 40 minutes long, but Zoom is cutting off at exactly 30 minutes. In other words, why is Zoom not working properly? I would appreciate any insight or advice on how to fix the problem of prematurely cutting off my Zoom meetings.
    I’m having the same experience- It cuts off at the “10 minutes to go” warning? Very frustrating in a 40-45 minute lesson
    I have the same problem. But I am not hosting, I am joining the meeting.  A weekly set meeting. I can connect from my phone for 2 hours and no problem but on my laptop it cuts off after 30min and it won't reconnect. I have tried closing and re-opening.  I have cleared the cach etc.
