Zoom audio/video session with Bose Quiet Comfort 45 headphones | Community
  • September 29, 2022
  • 7 replies
  • 7 views
Hi all,
Hope this is the right forum for this question.
I have been conducting Zoom calls (with both video and audio) using just the computer speakers and microphone.  In an effort to stop disturbing the family as much with my calls, I bought a set of Bose QuietComfort 45 noise cancelling headphones such that at least the family would not have to listen to the other participants speaking over the computer speakers.  However, because these are true over the ear headphones, during the one time I tried them out, I found myself speaking louder than usual as obviously the ear muffs dampen the noise.  It was like I was calibrated to hearing myself speak at a certain level and therefore wanted to speak even louder so I could hear myself at the same level.  Is this just something one has to get used to?  In other words, learning to speak at a lower volume knowing that you are being heard OK on the other end?  I found it really missed with my brain having these headphones on and my voice was a bit strained at the end of the call.  I got the headphones over against any of the "in the ear" devices where I understand you can just get away with only wearing one, but I despise these devices that you have to insert into your ear.  One thing I should note, is that I did have the noise cancelling feature on which may have made my own voice even more muffled to me, BUT from what I understand, NC headphones don't do much towards dampening voices, but rather constant frequency noises like engines etc.  Any input appreciated.
    Best answer by Ray_Harwood
    Hey, @HighTrails,
    This is actually a fairly common issue among headset and ear-plug listeners.  It's amazing how much we regulate our own voice based on our ability to hear ourselves, and with these devices blocking out even our own voices to a large extent, talking louder is the inevitable result.
    You don't mention which type of device you use.  If you are using a PC with Windows 10 (and this might work on Windows 11, but I can't confirm), there's a setting that routes the sound from your microphone to your headset... allowing you to hear yourself.  In "the business" we refer to this as "sidetone" -- hearing your own voice through your headset.
    Right-click the speaker icon in your Windows system tray:
    In the Sound window that pops up, click on Recording, then select the microphone you are using:
    Right-click on that microphone and select Properties from the submenu, then you will see another window pop up like this Headset Microphone Properties (yours will probably be named differently).  Click the Listen tab on that window, and check the "Listen to this device" checkbox:
    If the headset you're listening through is the "Default Playback Device", you can leave that selected, but if it is not, you can click the drop-down menu to select the headset you want the microphone to "play" into for listening.
    Give that a try and see if it solves your issue.
    If you're using a Mac... I'm sure there's probably a way to make this happen, but I don't know Mac very well.
    September 29, 2022
    Hey, @HighTrails,
    @Ray_Harwood Hi Ray.  Wow!  Thanks sooo much for your very detailed and informative reply.  I can't believe you took so much time with those screenshots and highlighting!  I'm new to headsets/headphones and didn't know about sidetone.  Your steps worked but unfortunately there is an annoying lag between speaking and hearing my words through the headphones.  The result is that I end up speaking an unacceptable slow speed to try and compensate!  I was trying to find some information about this on the internet.  Is this Bluetooth lag?  If so, what can I do?  I'm using these new QC45 Bose headphones with a relatively new Dell laptop running W10.  After reading all the great reviews on these headphones and how they work particularly well for conference calls and the like, I just can't believe it can be this bad.  Without enabling the listen mode, I did try turning off "quiet" mode (the ANC mode" and without ANC it is definitely better in terms of my voice not being muffled and not having to compensate my speaking volume as much, but it still bothers me I have to speak louder.  I'm hoping there is a solution to using your sidetone mode and fixing this lag.  Any further input appreciated.
    Just spent the entire morning trying to troubleshoot this.  I've tried resetting the headphones to factory default, updating Bose firmware on bose site, playing around with balance settings of headphone and microphone (as suggested by youtube videos where some were successful in decreasing lag by adjusting level on microphone slider), making sure Dell drivers and W10 up to date, connecting hardwire cable between headphones and computer thinking I could bypass lagging bluetooth,  but maybe that just hardwires audio and disables mic as then the mic didn't appear, etc.  Nothing is working.
    Anyone have any other suggestions I could try?  I just got off the phone with Bose and they had NO other troubleshooting ideas other than to resort that the headphones are defective.  In fact, they were confused the "listen" mode was "aware mode" on the headphones and it isn't!  Aware mode is the Bose term for ANC turned on.    I'm really doubtful these are really defective and still think there must be some setting, or something that needs to be updated, changed, bluetooth incompatibility, codec,  etc. I yet don't know about.
    Like the above user, I am trying Bose QC 45 for meetings Zoom and Teams from my Windows laptop. While my wife is happy with the older model Bose QC 35 ii for meetings from Macbook Pro, my Zoom meeting participants complain that my voice fades in and out.
    If I understand it correctly, Transparency Mode (aka awareness mode) allows you to hear external sounds while  listening to music so you are aware of your surroundings. Side Tone allows you to hear your own voice during calls so you are aware of your voice-volume.  Zoom also offers its own Noise Suppression (ANC) which is enabled as Auto by default.
    Question - how to manipulate ANC settings and the mic-volume settings on Zoom audio settings to ensure that headset and Zoom work nicely together?
    Thanks for your post!  Since I started this post, I have essentially given up.  Just to be clear, the issue I'm experiencing is if I don't have "listen" mode on (which I think you are referring to as side tone), then of course my voice is so muffled even with awareness mode on, that I find myself speaking louder than I need to just because I think our brains are calibrated to hear ourselves speaking at a normal volume such that if we don't actually hear that volume, we overcompensate.  Then, after learning about the listen mode, I tried that and it was a disaster.  I can definitely hear my own voice then through the headphones which was great but there was this slight delay such that it made me want to speak very slowly to try and compensate for that actually making one sound inebriated!  In the end, I gave up and stopped using the headphones for my zoom calls and just listening to music.  I think there must be a solution to his otherwise how could the QC45 get these great reviews for Zoom calls, etc.?  Unless these are just defective and I should just have Bose replace them.  So if you have success with getting these set up for your calls, I would love to hear your solution, or anyone else here.  I really would.
    I would note that Bose was pretty worthless.  I spoke at length with one of their representatives about this and they didn't even seem to understand the listen mode.  The only solution they had was to just have a new pair sent out which I didn't do.  I just had a hard time believing these could be defective, but rather the issue was in some setting somewhere I haven't yet discovered either with the headphones or within Windows 10.
    Open the Bose Music app on your smartphone. Then, under Settings and Preferences, select Self Voice (otherwise known as Sidetone or Mic Monitoring) and choose from the four settings, with High being the one I prefer when using Zoom, etc.
    THANK YOU!!!!! This solved it for me!!!!!!!!
    What about when using a MacBook with Zoom? The call starts out fine, then gradually the other participants hear a crackle, that gradually gets worse (although I can't hear it). Eventually the call has to be abandoned, but it's fine when I log in again. I have business fibre internet here so it's not that. Is this a Bluetooth connection problem that it gradually fades? Do I have to use a cable connection while on Zoom? Current workaround is to use the headphones but set Zoom's audio prefs to use the computer's microphone. Not ideal but it does stop echo feedback. I don't think it's the headphones as they are new, work well otherwise, and people seem to have been complaining about this for 3 years. All tips welcome! Thanks.
