Wayland screen sharing broken with GNOME 41 on Fedora 35 | Community
  • November 4, 2021
  • 94 replies
  • 319 views
I recently updated to Fedora 35 with GNOME 41. This GNOME release restricts the screenshot API which Zoom has used for screen sharing on Wayland, so the screen sharing functionality no longer works (see here on Ask Fedora).
I require screen sharing for school, and I'm sure many others have a similar requirement/system configuration. With Wayland increasingly becoming a de facto standard on Linux, it is crucial that Zoom support Wayland screen sharing.
Best answer by dalewe
It's not a bug in xdg-desktop-portal-wlr, so I'm not going to create a pull request to add code that does nothing (if the client is behaving correctly...). There's already work on supporting to share only a region of the screen (https://github.com/emersion/xdg-desktop-portal-wlr/pull/156) which should coincidentally also fix Zoom.
Simply running Zoom with "env XDG_CURRENT_DESKTOP=GNOME /usr/bin/zoom" should be enough to make Zoom think it's on Gnome while still keeping dbus working.
Edit: This should not be marked as solution! If any, https://community.zoom.com/t5/Meetings/Wayland-screen-sharing-broken-with-GNOME-41-on-Fedora-35/m-p/67283/highlight/true#M35878 provides a workaround for the issue, which has to be fixed by Zoom!
Any news about the 5.11? 😅
Support chat report: due to some bugs the release has been postponed to July 3rd. We must therefore wait until July 3 to discover the next procrastination date.
Perhaps by then we will even get updated release notes, also: Release on a Sunday?
I can confirm from my side that Zoom really has implemented this now properly and for me, it is working as expected.
Many kudos to @YaBoiB
The rpms on the download center look like they haven't been updated.  The webpage claims that you're getting 5.11.0 but if you run rpm -qpi on the rpm, it's still 5.10.7.
The same here.
wow fixed a lot (I am on 5.11.0 btw, with kde plasma)
pls remove this check, If you really fixed it, it should work on all DE's
edit:
THERE IS A WORKAROUND
firstly quit zoom in the tray, then open terminal and type this in,
XDG_CURRENT_DESKTOP=GNOME zoom
(you can also add that env variable to the desktop file to not do this with terminal every single time until they fix it)
and you should have fun with screen share, I have no idea why zoom forgot to remove this check, but nonetheless still disgusting to see the Linux port being neglected like this (still even after 8 months 🤦)
Where did you get 5.11.0? I go to the download page and it still only mentions 5.10.7. Also, I wish they didn't do those gatekeeping checks. I run Debian unstable, so Zoom's compatibility check is usually wrong. I wish they were more like Discord -- screen sharing hasn't had issues and none of these checks I have to work around.
I tried that earlier (and just now) as well. No luck. It says I'm up to date. I guess they are rolling the update out to some % of users first.
https://cdn.zoom.us/prod/5.11.0.3540/zoom_amd64.deb
Maybe last users commenting didn’t see:
“Support chat report: due to some bugs the release has been postponed to July 3rd.”
that is false, I have 5.11.0 on my computer right now
I tried to download it this morning and the 5.10.7 was present. I actually checked back seeing the 5.11 right now. Maybe support operator was uninformed at this point, but they told me release date was postponed. Anyway, will test the release once back home. 😉
I have also tested with 5.11 and it seems to be working flawlessly.
I have to point out that when issues like this appear , it still shows that some companies don't understand the Linux community. Just show a warning and let people still test it on their distros anyway.
Anyway, for us this is good news and thank you, we'll be doing an internal testing and if all good we'll probably get a pro license.
EDIT to clarify after some people reporting not working:
I'm on Fedora 36 and tested with somebody on the other end. I have 2 monitors and shared one of them and it worked. I will do more testing until the end of the week (as it's nigh time now here)
I don't think this is zoom not understanding the linux community, it's just zoom making a really really dumb mistake, by only supporting the GNOME desktop environment on an API that intentionally supports all wayland DE's.
I did some more testing, and screensharing is still broken, checking on another person's computer, all it says is [Insert name here] has started screen sharing with no actual screenshare
very disappointing indeed (I will restart my computer and check if that helps tho)
edit: still broken 🤦🤦🤦🤦🤦🤦, this update did not fix anything
I'm having this same issue.
So I installed zOOM 5.11.0 and verified that screen sharing works on my workstation. I'm running Debian unstable (bookworm/sid) with GNOME 42.2 / Wayland. Thanks for finally fixing this. (zOOM because they called GNOME "Gnome")
I really wish the fix could have been released sooner as a hotfix. I've had to ask co-workers to assist me with presentations as I couldn't share my screen and didn't have time to deal with workarounds.
did you check on another person's computer????
I am using KDE plasma and it is still broken, even with that workaround (cuz zOOM devs forgot that GNOME is not the only thing around)
edit: I am going to try modding the binary file to remove the check, if I succeed, I will post it here.
I think you may be able to modify your /etc/os-release file to fool it.
I did some digging and I think the binary uses this file to figure out which distro someone is running.
$ strings /opt/zoom/zoom | grep /etc/os-release
/etc/os-release
YaBoiB
Hey Team,
The Linux deployment has been slightly delayed for version 5.11.0, but it should be completed by tomorrow end of the day US time. Sorry for the inconvenience. I know that many of you have been waiting for a long time for this version to be released. I do not know the reason for the delay.
Brandon
could you fix the fact that it still says you need to use GNOME to screenshare in the next release? (though with a hack it "works" on any other desktop environment/window manager, but other users won't be able to see your screen)
It also doesn't make sense to place a random artificial restriction on screensharing when it is meant to work across all desktop environments
So, I _think_ it worked for a second or two (didn't get to check on another client) before it segfault'd
  1. Start Zoom
  2. New Meeting
  3. Share Screen
  4. Use system capture (complete with confusing screenshot, I think from Ubuntu?)
  5. Single Window
  6. *a window*
  7. Share
  8. [wait]
  9. kaput
It's just done it three times in a row
Update: Also consistently happens when sharing the whole screen
This on an entirely up-to-date freshly rebooted fc36 system.
Feels like delaying til the 3rd wouldn't have been a terrible idea…
