using zoom with an iPad and an iPhone (as a document camera)
Hi there,
Using an iPhone (as a document camera) with a macBook in Zoom is very simple, because you can share your screen with iPhone/ipad by airplay or by cable.
Using an iPad instead of a Macbook? there is no option to share the screen with an iPhone.
What for?:
we want to make a Zoom conference with our grandchildren per iPad with zoom.
the document camera (iPhone) shows a reading/picture book, which is under the document camera ("streamed").
The "stream" of the document camera should be shared in zoom,
so that the grandchildren can see the reading/picture book in full size and grandma/grandpa in a little window.
Do you have any hint for this use case?
thx a lot
Doro1
(Germany)
Sorry, I don't know, which "Select Location" would be the best.
