Uploading existing Zoom videos to Vimeo | Community
  • July 12, 2022
  • 2 views
I have only just discovered that you can link Vimeo to Zoom (not very tech savvy!) Is there a way I can upload all my existing Zoom videos directly to Vimeo? It takes AGES to download them and then upload them again. At least I won't have this problem in the future!
Best answer by Bort
There is no way to do this directly in Zoom, but there are a few integrations on the App Marketplace that can automate the process for you. Here is one I found you might check out: https://marketplace.zoom.us/apps/hmLqgaSsSxGxzRMKIkt4aw
Bort
BortAnswer
EllenRRAuthor
OK, I'll have a look. Thank you for your super fast reply!
