Universal Time being used instead of Pacific Time | Community
  • December 3, 2021
  • 13 views
My account is set to Pacific Time and I have participants across multiple time zones.  When I send out meeting invites it shows up as (UTC) Coordinated Universal Time for participants.  What can I do to correct this?
Thank you
    Hey @VDeimdowicz, when you scheduled your meeting https://zoom.us/meeting/schedule to ensure that the time zone is also correctly set. Also, are you using any calendar integration?
    This thread appears to older and i don't see any additional responses however, I have the same issue.  I use the outlook integration.  Every meeting comes into my outlook calendar using the Coordinated time rather than mountain. It drops the event in my calendar at the appropriate time however when you open the calendar event in outlook the time shows something different based on the Coordinated Universal time.   For example, I just had one come over for 2pm mountain time, which is correct.  However, when i open the event in outlook it shows 9pm.  How do i correct this?
