Unable to update the zoom | Community
  • November 13, 2022
  • 1 view
Hi everybody!!
Every time I open the zoom "your app version needs to be 5.8.6 or higher to sign in. Please contat your IT team to update your app". But I'M the IT. So
I tried to update manually from the settings and I didn't have the option.
After that I downloaded a more advanced version of Zoom to my computer and I still got the same message that I mentioned above. Does anyone have an idea how to solve the problem? Thank you
    November 14, 2022
    hi elad2022,
    i suggest that you uninstall existing zoom client and then reinstall it.
    this article explains uninstalling and reinstalling zoom clients.
    Uninstalling and reinstalling the Zoom application – Zoom Support
    this article explains required client update.
    Minimum, Prompted, and Slow/Fast Update Versions – Zoom Support
    can you sign in to zoom web portal?
    https://support.zoom.us/hc/en-us/articles/115005731743-Account-profile
