Unable to screen share in ubuntu 22.04 | Community
  • April 24, 2022
  • 33 replies
  • 185 views
I installed zoom on my freshly installed ubuntu 22.04 LTS and I faced a issue where i was only able to share whiteboard instead of my screen and there is no option other than that. How can i enable screen share? Is there any problem because ubuntu adopted wayland instead of xorg?
    Same problem here with latest zoom version (5.10.4) on ubuntu 22.04. LTS. No screens/apps displayed in Screen Sharing.
    I just realized that I was launched into Wayland after the upgrade to 22.04... If I log in into GNOME XORG, zoom screen sharing  is possible.. I did not use wayland before. I had also a few other problems with multiple monitors, which are gone in xorg.
    I have the same problem, also on Ubuntu 22.04 on Wayland. Screen Sharing used to work on Ubuntu 21.10 , also on Wayland (but only for the whole desktop, not single app windows), but not on KDE Wayland. On Xorg it always works, but it is extremely painful to switch the display server every time just to open a Zoom meeting. I would appreciate a timely solution to this problem.
    One workaround I found is to join the meeting from a browser (Chrome and Firefox both work), then you can share the whole desktop or single windows. This is good enough for the time being, but not very comfortable and has higher system load than the standalone Zoom app.
    Thanks for the workaround... That might help me until zoom receives a bugfix.
    same as me, there's no option for any windows. hope it would be fixed as soon as possible.
    ubuntu 22.04
    Having the same issue on Ubuntu 22.04 LTS with the latest Zoom desktop client version 5.10.4 (2845)
    Reporting same issue with Zoom, Webex and Skype - affecting all share screen functions - not just a Zoom problen - Wayland ? Trying Gnome
    try to do this
    Search to the custom.conf in /etc/gdm3/
    sudo nano /etc/gdm3/custom.conf
    uncomment the line
    #WaylandEnable=false to be WaylandEnable=false
    then reboot
    Thank you for the solution! it works for me. everyone should try this
    I have the exact same issue on 22.04 LTS - only whiteboard sharing available, nothing for screen sharing.  Zoom also frequently crashes while attempting to use the "share" feature.
    • Restart your system
    • There is gear icon (bottom right side) on login screen
    • Which have two options. First one is Ubuntu which is Wayland by default and another one is Ubuntu on Xorg.
    • You have to go for Ubuntu on Xorg
    thank you for providing clear GUI instructions for how to switch!
    Same thing happened with me. I wanted to share the screen and record it. It Just didn't show any option except whiteboard. It allowed me to share part of screen. When I watched the recording it showed nothing but just blank screen. Because of this I switched back to Ubuntu 20.04 immediately...!
    Is there a solution that does not involve reverting to X.org?
    zoom v5.11 is released. Will anyone please confirm, if you are able to share the screen in the latest version of the app or not..?
    It works. However GUI is different.  Say you have  two images opened as shown below, it does not tell you which one is which.
    However when it comes to apps and browser tabs or windows for example,  it does tell you which one is which.
    Honestly I like the latter GUI better.
