Unable to download recordings in bulk | Community
  • September 27, 2022
  • 6 replies
  • 1 view
Can we download multiple recordings from the cloud at once? If yes then please can someone help me with that?
    Best answer by Bort
    Hi @Hemanshu
    Unfortunately, that is not currently possible with Zoom. You would need to download them individually.
    An alternative is to use a marketplace integration that would automatically transfer your cloud recordings to another service that does have bulk-downloads, such as Google Drive. This app is one I know of, but haven't used it myself: https://marketplace.zoom.us/apps/5jjvtAZIQy-m-XkbchJMHg
    Bort
    BortAnswer
    Hi @Hemanshu
    In the main panel, select Cloud Recordings. Enter the search criteria to find a recording you want to download. Click More... and then Download to save the recording files to the local computer. (Zoom does not provide a way to do a bulk download.)
    Hi Hemanshu did you manage to download multiple recordings from the cloud at once?  can you please advise?
    HemanshuAuthor
    Nope.  Till now not able to download 😞
    Zoom is obviously making it hard so they can charge for storage.
    Yes, it's absolutely ridiculous that they don't give you access to your data.
    There are a few GitHub projects that attempt to do bulk downloading.
    https://github.com/lanec/zoom-batch-downloader
    https://github.com/ricardorodrigues-ca/zoom-recording-downloader
    there may be others as well.
    Regards
    Zoom gonna close JWT and all solutions uses JWT to upload any idea how to upload now that JWT is closed
