Speaker volume only too low on Zoom | Community
  • July 26, 2021
  • 5 replies
  • 9 views
Hardware is Dell Optiplex 990 desktop with  i5-2400 3.10GHz 8GB Ram 500G HDD Windows 10 64-bit
speakers are small  external with standard   3.5 mm wired connection connected to audio out port. Realtek High Definition Audio drivers.
 Zoom meetings are the only application where the volume is extremely low. Zoom volume setting and windows 10 volume setting  are up at maximum and I can barely hear.  For all other applications,  playing videos, etc. the volume from the speakers is extremely loud. There must be a Zoom setting or option that I am missing.  Please advise, thank you!
    vescamilla
    Hello d5,
    When you go to your Audio Settings for the Zoom client and you click Test Speaker, is this at normal volume or is it also really low? Also, please verify the correct speaker is selected in the drop down. Please advise -- thank you!
    d541_2Author
    7/29/21
    Hello vescamilla,
    On 7/28 I received the following gmail:
    Zoom Community <no-reply@community-mail.zoom.com>
    Wed, Jul 28, 3:05 PM (17 hours ago)
    Hi d5,
    driggerspei369 (Observer) posted a new reply in Meetings on 2021-07-28 01:05 PM
    I can't find the new reply, don't know if it was deleted or?
    Still hoping someone has an answer for this.
    Thanks, Don
    Update 7/29 9:30AM:
    Also something is not quite working right.
    This just now appeared in my thread:
    driggerspei369
    Observer
    ‎2021-07-28 01:05 PM - edited ‎2021-07-28 01:05 PM
    Hi, thank you for you answer. I tested the speaker in the Zoom client and made sure the speaker volume was at maximum and again the speaker volume setting in Windows 10 was also at maximum.
    This is part of my reply that I sent to you and it appeared in the thread as being sent by driggerspei369. No big deal, just thought I would let you guys know.
    Welcome to the Community and thank you for letting us know about this, @d541_2. The response from @driggerspei369 contained a copy/paste of your original response so I can definitely understand how that caused some confusion! I've moved that comment offline so that we can handle it privately.
    Regarding your ongoing low audio - thank you for already testing the speakers in the Zoom client itself. I'm wondering if there is possibly a third party soundboard controlling Zoom volume on your computer? On Windows, on the right bottom corner of the taskbar, please try right clicking the speaker icon and clicking on “Open Volume Mixer”. Once there, find “Zoom Meetings” and adjust the volume and see if this helps.
    This didn't work for me. My speakers work well on all apps except zoom. I can hear spotify and computer sounds just fine. Zoom is the only app with sound issues and I can't figure out why. I tried the Volume mixer and tried multiple output device options.
    I found out that having another app using the audio made Zoom audio lower its volume.  In my case it was a Google Meet browser tab. Close it and voila!
    How did you figure out that Meet was using your audio?
    Hi have a Dell laptop (Latitude 7410) and was having the same issue.  What worked for me was by un-checking the "enable audio enhancements" in my computer's sound settings.  For a step by step:
    Try going to Sound Settings (right click the speaker icon in the bottom right on the toolbar).
    In Sound Settings, click "Device properties"
    Click "Additional device properties"
    Click on "Advanced" tab
    Un-check "Enable audio enhancements"
    Select "Apply"
    Note - if you have Zoom open, the audio will stop when you do this.  Just close and re-launch Zoom and hopefully the speakers will come through much more loudly!  Good luck!  I know how frustrating this is!
    Aww thank you so much for responding. I have a surface pro. But I did find what you suggested and un checked it. Praying that works. You are right so frustrating cuz I’ve not had this problem b4. Keep ya posted.
    I had this problem. The microphone sound on a Logitec 925e webcam was too low. It was OK for a Senheiser headset. The Microphone level was OK when tested with the in built Windows Mic test software.  I found I could get the mic  level restored by going to Settings- Privacy -Microphone , Then switching off all those applications that I don't use or don't have a reason to use the microphone
    Thank you so much! It takes a village! I produce a podcast for someone who is incarcerated and he is on speaker while the guests are on zoom! So I only get one shot. But all is fixed once I unchecked that pesky enhance audio enhancements.
    be well.
    Macbook m1 Pro 2021 and macbook pro 2018 6 core i9.  Both absolutely suck with the latest version of zoom .  I produce live events and often have to bring in a remote presenter on zoom.  It worked fine last year w the same machines.  This year with new zoom updatees both macs output almost inaudible signal via headphones port.  all other applications output at full volume.  The difference in thee zoom output is almost 1000% lower than othre applications.  This ruined a great product and leaves me hunting for new solutions to a solution that usd to be solid.   Nothing to change on the mac.  It just plain doesnt work for audio output whether via headphone or usb audio.  Only zoom can be responsible for this.
