Speaker volume conrols on computer no longer work when using Zoom 5.14.11 (17466) | Community
  • June 15, 2023
  • 6 replies
  • 82 views
When in a Zoom meeting, I used to be able to adjust desktop speaker volume of my using my computer's volume controls.
Now, they do not work on Zoom volume -- instead, I have to go into Zoom Settings/Audio and move the slider.
Is this a setting issue? Or did Zoom change this?
CarlaA
Hi @Zman23, thank you for posting for the first time, and welcome to the Zoom Community!
It's possible that there is a Zoom application setting that is overriding the system audio controls. To check this, go to the Zoom Settings and navigate to the "Audio" section. Ensure that the "Automatically adjust volume" option is enabled. This setting allows Zoom to adjust the volume based on your computer's volume controls.
Let me know if that does it!
Carla,
Zoom Community Team
Please click Accept as Solution if you found this reply helpful. Thank you!
HI,
I'm also having this problem, and I can no longer find the checkbox to "Automatically adjust volume".  Instead, the checkbox under the Speaker Volume slider now say "Use separate audio device..."
This is Zoom client for Windows 11 version 5.17.11.
Thanks,
Nir.
jaustria
Hi - Welcome to Zoom Community - You can try these steps if as well if you are using windows.
On Windows devices, you can use the volume mixer to adjust the volume of individual apps, however, there is no way to do this on macOS or Linux devices without downloading 3rd-party software.
  1. On your Windows computer, in the lower-right corner of the taskbar, right-click the speaker icon.
  2. Click Open volume mixer.
  3. Under Apps, locate Zoom Meetings.
    Note: Multiple Zoom options may be available. Try each one to determine which is the correct option for adjusting only the volume of the Zoom meeting.
  4. Adjust the volume slider as needed.
    The volume in a Zoom meeting will increase or decrease based on your selection, while your computer’s volume will remain the same.
Jett
Hi Jett,
I've been having the issue described by the OP.
The steps you set out above do work, though my question is why?
  • Why doesn't changing the computer's main volume affect audio from Zoom? (like anyone would expect it would?
  • Why doesn't the volume control within the Zoom settings work? (ie, on a call right now, and the volume slider does nothing.
Please can both of these issues be fixed asap, no one should have to open a fairly hidden Windows setting (volume mixer) to change the volume of audio in an app, the main volume control should do this (always, for all applications).
Thanks
Matt
This problem suddenly started happening to me during meetings in January 2025, and it's absurd that this issue is still a problem. The option to automatically adjust volume according to computer settings has disappeared for me, too. Finding and adjusting the volume settings in the middle of a meeting presentation is a horrible, especially when I'm in the middle of sharing my screen. I now have to open the settings window and keep it up throguhout my meeting to manually adjust the sound. The window is huge and takes up half my screen and is always on the top of other windows, obscuring windows that I need to see during my meeting. I'm using the most updated version of Zoom. This is unacceptable - how has zoom not updated this problem yet?
I have the same issue in March, 2025. System audio controls (volume up/down and mute) do not affect Zoom audio volume. This is ridiculous. Zoom, please fix this.
Hello @jthornbrue! Welcome to the Zoom Community! We're glad to have you here. May I know what device, operating system, and Zoom version you are using?
 I am having the same problem.  I don't have the option to change the speaker as the other individual listed above.  Is there a solution?
It's October and this Issue is STILL happening. Any found a fix? It worked fine until last week now changing my computer audio doesn't change the output volume.
Found Reseting the driver used for my Bluetooth Device and and adjusting the volume level in the old school control panel corrected the issue of being able to control Zoom meeting volume using the master volume control
Step 1: left click on "Start (button)"
Step 2: keyboard input on "Search (window)" in "Search" [...]
Step 3: left click on "CoreInput (pane)" in "Search"
Step 4: left click on "Search Box (edit)" in "All Control Panel Items"
Step 5: keyboard input on " Search Control Panel (pane)" in "All Control Panel Items" [...]
Step 6: left click on "Sound (link)" in "sound - All Control Panel Items"
Step 7: left click on "Headphones (list item)" in "Sound"
Step 8: left click on "Properties (button)" in "Sound"
Step 9: left click on "Properties (button)" in "Headphones Properties"
Step 10: left click on "Change settings (button)" in "Jabra Elite Active 65t Properties"
Step 11: left click on "Driver (tab item)" in "Jabra Elite Active 65t Properties"
Step 12: left click on "Update Driver (button)" in "Jabra Elite Active 65t Properties"
Step 13: left click on "Browse my computer for drivers (button)" in "Update Drivers - Jabra Elite Active 65t"
Step 14: left click on "Let me pick from a list of available drivers on my computer (button)" in "Update Drivers
Step 15: left click on "Audio Sink Service (text)" in "Update Drivers - Jabra Elite Active 65t"
Step 16: left click on "Installing drivers... (pane)" in "Update Drivers - Jabra Elite Active 65t"
Step 17: left click in "Update Drivers - Audio Sink Service"
Step 18: left click on "Update Driver (button)" in "Audio Sink Service Properties"
Step 19: left click on "Browse my computer for drivers (button)" in "Update Drivers - Audio Sink Service"
Step 20: left click on "Let me pick from a list of available drivers on my computer (button)" in "Update Drivers - Audio Sink Service"
Step 21: left click on "(button)" in "Update Drivers - Audio Sink Service"
Step 22: left click on "Close (button)" in "Update Drivers - Jabra Elite Active 65t"
Step 23: left click on "Close (button)" in "Jabra Elite Active 65t Properties"
Step 24: left click on "Levels (tab item)" in "Headphones Properties" Step
Step 25: left click on "Desktop (list)" in "Headphones Properties"
Step 26: left click on "Jabra Elite Active 65t (text)" in "Sound"
Step 27 left click on "Headphones Properties (dialog)" in "Sound"
Step 28: left click on "Levels (tab item)" in "Headphones Properties"
Step 29: left click on "Headphones (slider)" in "Headphones Properties"
Step 30: left click on "Mute (check box)" in "Headphones Properties"
Step 31: left click on "Mute (check box)" in "Headphones Properties"
Step 32: left click in "Headphones Properties"
Step 33: left click in "Sound"
Step 34: left click on "Volume Headphones (Jabra Elite Active 65t): 77% (button)"
Step 38: mouse drag end on "Sound output (slider)" in "Quick settings"
Step 39: left click on "Sound output (slider)" in "Quick settings"
Link to PDF with Screenshots https://1drv.ms/b/c/561d12226bd7d4cb/EWpptZccX3NAslNGBvNs5XAB50Hn921lsNFMKwBeVrItZQ
Windows 11 Pro 25H2 Build 26200.6901 - Zoom 6.6.5 - Having to Go into the Volume Mixer to adjust zoom meeting volume is not an acceptible work around. We should be able to use the master volume control As we have been able to for years before.
