sound | Community
sound
  • November 9, 2024
  • 7 replies
  • 7 views
Recently my contacts hear me with echo, which makes meetings unbearble.  As far as I could realize,  this phenomenon takes place whether I initiate the meeting or join someone else meetings, and whether I have single contact or participate in multi participants meetings.  I use my Lenovo tablet for my zoom activity.  Can you assist me?
Best answer by stueker
@kmacsouris Could you please check under "Settings" -> "Audio" -> "Advanced" (at the bottom of the page) There you have settings for Echo cancellation. Can you check, if the problem still occurs, when you set the echo cancellation to auto or to high?
Are you using a bluetooth ear piece when on these calls or are you using the built in mic and speakers on the tablet?
The built in microphone  and speakers, sometimes I use a headset that plugs into my computer.  No bluetooth
TsviGilAuthor
I use the mic and speakers of the tablet
TsviGilAuthor
Since it happens in both single and multi-participant meetings, it may be related to microphone feedback from the tablet's speakers. Using headphones or lowering your tablet’s speaker volume can help, but you may also want to check for any updates for both Zoom and your device. If the problem persists, reinstalling Zoom might also help fix any glitches.
stuekerAnswer
TsviGilAuthor
Thank you all.  I bought headphones combined with microphone  and the problem was solved.  The sound quality improved significantly.
TsviGilAuthor
