Showing timer to participants is not an option | Community
  • June 20, 2024
  • 3 replies
  • 0 views
I tried referencing this article - Using the Zoom Timer App
But the Show timer to all toggle control does not appear on the Timer app. I'd like to show the participants the timer while they are presenting.  Are there settings I need to adjust in order for this toggle to appear?
Thanks.
Best answer by ness_15
I resolved this. The toggle option finally showed up by updating my settings in the Zoom web browser > Settings > Zoom Apps > toggle on for Zoom Apps Quick Launch Button. That made the Timer app "show timer to all" toggle control show up.
June 21, 2024
The "show timer to all" switch only appears when the timer is NOT running and it appears in the lower right of the timer window. So you need to set the switch before you start the timer.
I do not have this toggle option either. I opened the window to set the timer. I did not start it. The only options I have are to share the app with others and to share sound or not.
I do see that I am in "guest mode." Does that affect the ability for me to be able to share the timer with others?
ness_15AuthorAnswer
