Says my device does not support virtual backgrounds or blurr, but when I look up the requirements... | Community
  • August 31, 2021
  • 18 replies
  • 84 views
My device appears to have the requirements for virtual backgrounds or blurr but Zoom tells me it doesn't. I looked them up. What can I do now?
    Best answer by rn-zm
    Hi @SteveW68 it's been some time since you've posted this discussion! Just need specs of your device to ensure you meet the requirements from our KB on  virtual background system requirements
    Bort
    Hi @SteveW68
    Well, can you provide your system specifications, so that we can double-check that you meet the system requirements for Virtual Background?
    I have the same problem and says doesnt support virtual background.  I have HP laptop Intel(R) Core(TM) i5-2540M CPU @ 2.60GHz 2.60 GHz with 4 GB Mem/ 500GB HDD , x64 processing
    Can anyone help to fix this??
    Bort
    Your processor is what is not meeting the system requirements. Your processor is a 2nd generation i5 processor with 2 cores. The virtual background system requirements state you must have at least a 3rd generation i5 processor with 2 cores.
    My HP Stream 11 doesn't have anywhere near that kind of power and runs it easily, so how can you say it needs that.  What is Zoom trying to accomplish here.  Why has the bar been set so high when it really doesn't need to be???
    rn-zmAnswer
    I just started using my desktop as my 'advanced gen laptop' was struggling to cope with Zoom audio.
    My desktop with  Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz 3.40 GHz and 16GB Ram is said to not meet Zoom requirements.    https://www.intel.com.au/content/www/au/en/products/sku/52213/intel-core-i72600-processor-8m-cache-up-to-3-80-ghz/specifications.html
    My kids play a whole range of games including Call of Duty, Cyberpunk 2077, Fortnite, Apex Legends, Rainbow 6 Seige (R6), and World of Warcraft Shadowlands, yet I cannot use a Zoom virtual background.  Is the bar set too high for Zoom ?
    Hi Steve,
    Mine is Intel(R) Pentium(R) Gold 7505 @ 2.00GHz 2.00 GHz; and I am experiecing same problem...any reason why?
    Hi @Bort and @RN52_2 ,
    I get the same issue.  Here's my computer specs:
    AMD A8-9600 RADEON R7, 10 COMPUTE CORES 4C+6G  3.10 GHz with 8GB RAM.
    What could be the other reason?  Appreciate your comments or recommendations.
    Thanks,
    Eleanor
    Bort
    Hi @eleanorgrace
    As far as I can tell, the specs for the AMD A8-9600 Radeon R7 show only 4 cores, which is not sufficient  for image without a green screen or blurred background.
    Thanks @Bort for the reply.
    Appreciate it.
    My system is  AMD Ryzen 3 PRO 2300U w/ Radeon Vega Mobile Gfx 2.00 GHz.
    I am assuming it doesn't work for Image Only without Green Screen but it works for  image only with green screen.
    For Video Background without green screen, it looks like it's listed but I can't select any of those.  Did I misinterpret the requirements?
    Kate
    Mine is also saying not supported.   Here are my specs:
    Intel(R) Celeron(R) G5905T CPU @ 3.30GHz 3.20 GHz
    Bort
    Hi @Franswahili
    Unfortunately, the Celeron line of Intel processors all seem to be below the system requirements for virtual backgrounds. Intel processors are supported from the Intel Core i3 product line and higher.
    No they ain't, you yourself have said it must me i5 and above
    Hello! I am getting the same error. However, I have an i5 processor. Here are my specs
    2.6 GHz Dual Core Intel Core i5
    16 GB 1600 MHz DDR3
    Intel Iris 1536 MB
    Its a Late 2013 Macbook running 10.15
    Hello.  I have the following processor etc. and it is not allowing me to do a virtual background.
    AMD A10-8700P Radeon R6, 10 Compute Cores 4C+6G 1.8 GHz (0 processors)
    PC Laptop-DEQGNG87
    Windows 10 Home
    OS Build 14393.2214
    RAM 8.00 GB
    64-Bit
    Please let me know why it will not allow the virtual background.  Thanks.
    Where are the zoom developers?
    They should fix these issues!
    It does not make sense; I can use my laptop for full resolution gaming but not for zoom??? Seriously!?
    Here are the spect of my laptop.
    Processor
    1x AMD Ryzen 3 2200U Processor(AMDRyzen3 2200U)
    Memory
    1x 8 GB DDR4-2400
    1x 4 GBDDR42400
    Operating System
    Windows 11 Home 64
    Hard Drive
    1xTB SSD
    Wireless Network
    1x Bluetooth® 4.1; Lenovo Wireless AC
    Ports
    1x Combo Audio Jack; 1 USB 3.1(Type C); 2 USB 3.0; 4-in-1 SD-Card Reader (SD
    MMC
    SDHC
    SDXC); HDMI 2.0
    Camera
    1x 720P
    Graphics
    1x Integrated AMD
    Monitor
    15.6 1366x768
    Hey @efraguzskmx your CPU is a Ryzen 3 which is equivalent to an intel 3 processor which is not supported; therefore, you will need (in your case) a Ryzen 5,7 or Intel i5, i7.
    Please see the Knowledge Base Article on Zoom Virtual Background system requirements for more info. Thanks!
    So why does a HP Stream 11 run the Virtual Backgrounds then??? Nowhere near the processing or graphics power of that system but it runs it. Easily.  How does that work????
