Recurring meetings | Community
Recurring meetings
  • July 11, 2023
  • 19 replies
  • 13 views
Since ZOOM updated yesterday, I cannot find my recurring meetings
Best answer by Ray_Harwood
IMPORTANT UPDATE:
Zoom has listened!
The removal of the Home tab and replacing the contents of the Meeting tab with the one-day calendar of events has been REVERTED.  Log out and back in on your desktop app to see the Home and Meetings tabs at the top, and select the Meetings tab to see the layout previously available prior to the roll-out of 5.15.3.
Please see this Zoom Support article for details:
https://support.zoom.us/hc/en-us/articles/17564111105677
Today you can find your recurring in the calendar on the homepage when you sign on for your Zoom meeting (NOT the website.  The app).  Click on the very small print "Any Time Meetings" and you will find your list of recurring meetings.
I cannot find my calendar. it says calendar across the top menu bar but then nothing. and there is nothing that says "any time meetings".
Click on Meetings icon in the top menu bar.  You will get the screen with New Meeting, Join, Schedule, and Share Screen. To the right is a clock/calendar icon. Within that box, towards the bottom, is the "Anytime Meetings" that you click on and it will show your recurring meetings.
Me, too. All of my recurring meetings are accessible by logging in through the web, 'zoom.com,' but what a pain!
I should have said, 'zoom.us'.
Me too, whats the solution?
Log onto Zoom for your meeting.  There is a calendar on the homepage.  Click the small print "Any Time Meetings" and you will find your list of recurring meetings.
 Same here 😣 Anyone found a solution yet?
See my response to previous poster.
If I open zoom in my phone the recurrent meetings are all there, but in the computer they are not and the line you mention doesn't show up in my screen. The solution I found is to open the meeting in my phone and then switch to the computer. Something is wrong with Zoom
same here. I've alerted Zoom a few hours ago but nothing so far.  I can see the other way to see them but that takes ages, I have to keep asking it to show them all and not just 15, and cannot see any way to get them in alpha order. I thought they knew how important this was to us all.
I have posted three responses to this.  Scroll through the news feed on this question to find them.
Something is wrong with Zoom.
The solution I found is to open the meeting in my phone and then switch to the computer. (The phone version shows the rec. meetings)
I can't even find the "Any Time Meetings" line mentioned by Alexand875
July 12, 2023
See the yellow highlight here:
Hello Ray
This does not show up on my Zoom on my computer.
Are you on mobile or computer?
This is what shows up for me...
Hi all,
"anytime meeting" does not show up in my Windows zoom client, either. What a pain! Can we seriously tell Zoom not to change interface randomly without notice.
July 12, 2023
Welcome to the Zoom Community, @henryhongbojin.
What version of software do you have installed, and what OS (Windows or MacOS)?
Are you sure you have "anytime meetings" available to see?  I do see the dropdown on accounts that have some available, and on other accounts where there are none... the dropdown is indeed missing.
Thanks Ray, I used Windows zoom client, version is unclear, seems automatically updated. I can see my recurring meeting in web portable as below.
I was so at ease and happy with old format where I could just have recurring meetings with my PMI.
And could click on copy invite and send link. Please bring it back or I will probably cancel my Zoom Acct.
On MacBook Pro.
Same here... I'm furious about that! I have a PRO Plan and I simply cannot access my 20+ recurring meetings from the Client App.
Zoom is becoming such a trashy platform!!!
Check for updates.  I saw that above in this string, checked for updates, installed the updates and the new format shows the Anytime meetings.  The update is needed to bring them back into view.
Is not there is at the zoom program (app, no web. Just run zoom and search this
Press anytime meetings
I get it! Just update again and then press "anytime meetings". 0% intuitive
