prevent a guest to go total when speaking | Community
  • December 10, 2024
  • 3 replies
  • 0 views
Hi , how can I prevent a guest to show as total the he or she speaks. I need that my guests remain In the small image on the right. But now when someone speaks up his image turns into total.  Is it possible to avoid this?
Cheers
Js
December 11, 2024
There are numerous templates that control video images in Zoom. But it is not clear exactly what you are asking the software to do when you say "remain in the small image on the right". Screenshots would be helpful to see what you are seeing.
Jim_the_Scot
Click View. Make sure you are set to Gallery, not to Speaker.
You can use different recording layouts depending on your meeting's video setup. Some layouts work with computer recordingscloud recordings, or both. Computer recordings reflect the view of the person recording, while cloud recordings follow the host’s settings and can capture multiple views simultaneously.
More information
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0062314
Regards
JHaroAuthor
Thks for your answers. I will read the link and let you know how it goes.
