Pre-assigned participants not making it to breakout room & couldn't assign them to the room | Community
  • October 3, 2021
  • 3 replies
  • 8 views
A handful of our participants didn't make it to their pre-assigned breakout rooms. They were using the Zoom accounts they signed up with. Also, I couldn't assign them to their rooms from the main room.
Any clues on how to resolve before tonight's meeting?
@Nafi @Bort
    Best answer by Rupert
    Hi @CampBlueSkies
    I would ensure that the email addresses you pre-assigned them with matches exactly their registration email addresses, and, if they are authenticated users, the email addresses they are signed into Zoom with - if any.
    I would also ensure they are all using their unique join links - and no one is using a generic link.
    I would then also ensure that you, and they, are all up-to-date with the latest version of Zoom.
    https://support.zoom.us/hc/en-us/articles/201362233-Upgrade-update-to-the-latest-version
    Then also try assigning a Co-Host in the Main Room to see if they are able to move stray participants to breakout rooms, if this is still a problem.
    Hope this helps.
    Rupert
    Rupert
    RupertAnswer
    Hi @CampBlueSkies
    Hope this helps.
    Rupert
    Thanks, @Rupert ! Will do all of that. I'm betting it's latest update of Zoom issue. 🙂
    I have the exact same problem.  I have created 6 break out rooms and uploaded with the Zoom csv template.  All but 4 participants save to the room to which they have been assigned.  But 4 participants, no matter how many times I assign them to a breakour room.  I enter them, I click save.  and they show in their respective room.  I refresh the page and they just diasappear.   I have added them using the email address they registered for the meeting (recurring) with.  So this is causing a problem every week.   It seems the 4  that wont save are the last 4 to register.  We only have 60 registrations so have not exceeded the 200.   I'm very frustrated.  Help appreciated.
