photo not showing on screen when camera off | Community
  • December 27, 2021
  • 13 replies
  • 35 views
I have downloaded a photo, but it doesn't show when I'm in a zoom call and stop my camera...just my name shows.
    Best answer by Bri
    Hi! Sign in to the Zoom web portal. In the navigation menu, click Profile. Then, click your profile picture to add your photo or change it. For more information, check out this article https://support.zoom.us/hc/en-us/articles/201363203-Customizing-your-profile. Hope this helps!
    Bri
    BriAnswer
    I have done what you recommend and it still does not work. When in a meeting it is just my name when I turn the video off and I have a photo uploaded.  One other thing, when I am on a Zoom meeting that someone else is hosting my name is in all lower case.
    Same here!
    Agreed! Wishing they would solve this issue!!!
    Same here. I haven't had my profile picture show for over a week while others on the call have theirs showing..whether i am signed in or not 😞
    cjrhoads
    You have to do more than sign in - you have to sign in and then manually enter the meeting id and password.  If you use the link, it signs you out and enters you as a guest even if you just signed in.
    I am having the same issue. When I am in my own Zoom account, only my name shows if my video is off, despite the fact that I have a profile pic in my profile. When I log on to other people's Zoom meetings, my photo shows up. Everything I've seen online I've either tried or I can't try (for example, people say to bring up the participant list, click the "more" button next to your name, and then click on "add profile picture." I don't get that option--I'm guessing because I already HAVE a profile pic; it just doesn't show up.
    dears
    very frustrating to read all possible solutions and that nothing works!… a solution to this seemingly simple Problem is really expected from Zoom Support (and/or Community…).
    what is the use of having a Profile picture if one cannot use it?!
    OK, my bad. I figured out something that worked for me...I went into Settings/In Meeting (Basic)...at the very bottom of that section there is a setting "Hide participant profile pictures in a meeting." I turned it off and I now see my profile pic. Good luck.
    I tried that.  Still nothing.
    Very frustrating
    will try the security tab and unchecking hide profile next time on zoom
    This happened to me also.  I went to my profile in the browser and deleted and re-added my photo.  Then, I had to activate it by hosting a zoom meeting (just myself).  I turned off the video and my photo was there!  I hope this works for you.
    Thank you!
    I have set up a second free account, and I have the same issue with both! When I turn my camera off in meetings, only my name shows, and I have a profile picture in both accounts. I'd never upgrade to a paid account while Zoom is unable to fix this type of issue.
    cjrhoads
    The question isn't just whether you have uploaded a picture - it's HOW you get into the zoom call.  Did you just click on the link?  Or did you first go into your own account and use the JOIN option to enter the meeting ID and password for the zoom call you are going into?
    Your photo will only appear when you are logged into your own account, and clicking on a zoom link can sign you out of your account so your picture won't appear.  (This doesn't ALWAYS happen, but is USUALLY happens.)
    If this also happens when you are the host and you did log into your own account and START the meeting, then that would be a problem, but you didn't say that.  You just said "in a zoom call".
