Participant videos freezing | Community
  • August 16, 2021
  • 34 replies
  • 3 views
I have used Zoom for over 19 months with no issue. Suddenly, in the last 3 weeks, my clients videos are freezing, I can hear them but can't see them. They can see and hear me. I have tested the internet connection speed and have done the check from multiple locations. I have a feeling this started after my last software update. Anyone else experiencing the same? BTW this is happening with multiple groups of clients.
Thanks!
    Best answer by ZoomVA
    Hi @CN29_2 Please try adjusting the video settings in Zoom Client -> Settings -> Video -> Advanced -> Uncheck Receiving Video in the section (Use hardware acceleration for), and see if this solves the issue.
    ZoomVA
    ZoomVAAnswer
    I applied this fix as well as reinstalling Zoom a couple of times and it still freezes.  Does make any difference if on Webinar or one on one.  What's next?
    I'm facing the same problem here! I'll try your tips"
    Thanks!
    Thank you for the tip.  I will try it today.  Fingers, toes, and eyes crossed.
    Exactly the same thing here, both on my HP desktop and my HP laptop.  I can briefly unfreeze the other client's videos by changing from gallery view to speaker view, or back again.  I will  try this solution and post again with results.
    Yes! Finally! This very thing is happening to me! Is there a fix???
    See above for fix - follow the step and it works for groups and individuals
    You would think that with so many folks having this very same issue that Zoom would fix it!!! Come on Zoom, I am paying good money!
    if you are paying good money, zoom offers you support, i'm fairly certain.  i have the free set-up, so i get no help, except for here.
    Hi i have followed the instructions for the fix. It is better in that it is not constantly freezing, with me having to unfreeze throughout the meeting. However it will now pause audio and video it will start again on its own but there is then a delay and miss some of what is said.  Any advice for this please
    Exact same issue for me too! Only over the past 3 weeks. To survive my meetings, I've been changing the view from "speaker" to "gallery" and it will unfreeze their video, but only for 1-3 minutes. Sooo frustrating.
    Try the solution, it worked for me.
    did the recommended solution work for you? i'm in the process of working with DELL. i need help.
    The same thing is happening to me.  It started about 4 weeks ago.
    yep.  have tried everything. dell was going to replace my motherboard on a 6th-month old computer.  i hope the suggested setting change helps.  i'll find out tomorrow when i go to work! And...it worked!
