No option to rotate camera | Community
  • October 21, 2022
  • 4 replies
  • 4 views
Hello! After the Zoom update it seems the interface has changed quite a bit and there are fewer available settings. For example, I cannot rotate my camera in 90 degree increments anymore, which used to be an option in video settings when hovering over the video preview. As a result, my document camera projects the image upside down and I no longer have a way to correct this in Zoom. I checked the article on Zoom's website already on Manually Rotating Camera which no longer applies because it was last updated in March 2022...but the updates happened after that.
Any advice?
    Best answer by Bort
    Hi @bcalmer
    I'm on the very latest desktop client and still see the option in my settings.
    Which version are you on, and which OS (Windows, macOS?) are you on?
    Can you provide a screenshot of the video settings window?
    Bort
    BortAnswer
    Hi @bcalmer
    Hi I have a similar problem on my new s9 ultra galaxy tablet. My camera turns me 90degrees randomly. Any idea why this is happening? I've reinstalled zoom and abled and disabled auto rotate. There's no video options on Android tablet apart from background thanks
    bcalmerAuthor
    Okay I just did more digging on the web and apparently my problem is that I'm on the PWA version? I don't even know how that happened. I just tried redownloading the regular Zoom desktop client but the PWA version is still there on my desktop...cannot figure out how to uninstall it. I guess I have a new and different problem now.
    bcalmerAuthor
    Alright, I think everything is resolved now. Thank you!
    Is this still an issue? I have NEVER had this issue until a few updates ago. I have plugged my iphone (iOS 17.7) into my mac (OS  14.6.1) and on Zoom I would choose ipad/iphone via cable and if I turned my phone horizontal, I got a horizontal camera. NOW on current zoom (6.2.6) it no longer allows the image to rotate. AND it does not seem to recognize any virtual cameras anymore like ManyCam or Epoccam.
