My video flickering since update yesterday | Community
  • January 12, 2023
  • 5 replies
  • 11 views
Zoom updated yeterday and since then, my video is flickering with a green color. I can see the other video fine during a meeting and the other participants also see my video flickering. I tried reinstalling Zoom 2x including with the Zoom Unistaller and changed the video rending method from auto to Direct3D11 and 3d9 with no success correcting this. Note that I have Windows 11 and also updated Windows yesterday too. I could really use some assistance. Thank you.
    I had this problem yesterday also after updating Zoom on Windows 11.  Any answers out there?
    I'm experiencing exactly the same problem and sorry to say, I have no solution. Nobody at Zoom who can help because the package I pay for doesn't provide it.
    Found this post. I have made these changes and so far so good.
    I had to go into the video settings & change 2 things:
    1) Change the "Adjust for low light" from Auto to "manual"
    2) Click the "Advanced" (in video settings still), and uncheck the "Optimize quality of the video/send with de-noise"
    So far so good, it has been a fix for me, hope this helps you too!!
    How do I find video settings?
    I had the same flickering green and freezing video issue, after a Windows update. I went into advanced video setting and  unchecked the Optimise quality of video. It worked for me as well. Thanks!!
    Yesterday I updated ZOOM - no longer have the problem - Did a ZOOM meeting this am.
