My microphone isn't working | Community
  • October 20, 2021
  • 3 replies
  • 0 views
My microphone has suddenly stopped working in Zoom. I've recently upgraded to Windows 11 but I don't know if this is anything to do with it. I've uninstalled and reinstalled Zoom and I've checked that all the device drivers are up to date.
Zoom tells me that the device is not working properly.
I've spent hours trying to sort the problem today and I'm out of ideas. Can anyone help?
    Rupert
    Hi @dannal1
    I would ensure you are running the 64-bit version of Zoom:
    https://zoom.us/client/5.8.1.1435/ZoomInstaller.exe?archType=x64
    dannal1Author
    Hi Rupert.
    @Rupert wrote:
    Hi @dannal1
    Yes, I have the latest 64-bit version installed. I also just tried rolling back to Windows 10 but it still didn't work. I'm back on Windows 11 now...
    Hi! I am having the same problem, also recently upgraded to Windows 11. Did you find any solution?
    dannal1Author
    Hi! Yes, I did. I was helped by a Zoom staff member.
    There are two settings to change.
    1.
    Within Zoom, go to Audio settings.
    Select 'Advanced' at the foot of the screen.
    Select “Signal processing by Windows audio device drivers” to “Off (Windows - Raw)”
    Then...
    2.
    In Windows Settings, go to Control Panel → Hardware and Sound → Sound
    In Sound, right click the device (i.e. the microphone) being used and select Properties
    ​Click on Advanced tab, then uncheck “Enable Audio enhancements”, and click apply.
    This worked for me but you might have to do a reboot after you've changed the settings.
    Good luck!
    Dave
    dannal1Author
    Hi! Thank you for this. Unfortunately I followed the steps and also restarted my computer and still didn't work 😞 how did you reach out to a Zoom staff member to get help?
    I contacted Zoom Support.
    https://support.zoom.us/hc/en-us
