My Logitech Brio webcam recently stopped working. It does not work only on Zoom. | Community
  • May 15, 2024
  • 50 views
Hi there
Need your help urgently. My Logitech Brio webcam recently stopped working. It does not work only on Zoom. I use a MacBok Pro on MacOS Sonoma 14.4.1 on 16 GB RAM. When I choose my Logitech Brio as my webcam, it is blank black screen and sometimes shows a distorted image with green noise all over. When I switch my camera to the built-in FaceTime camera of macbook, it works perfectly fine. I have uninstalled, reinstalled the app, I have restarted the machine many times, I have installed Logitech G-Hub software and LogiTune software to control the webcam. webcam works fine in those software. Webcam is not working for the Zoom workpace app.
For over 2 years, this same webcam worked perfectly fine on this same laptop with zoom until about a few weeks ago.  I am not 100% sure of this obseration... but I think the trouble started when I upgraded to Zoom Workplace app on my MacBook Pro.
How do I make the Brio webcam work on my Zoom meetings? Please help.
regards
Raj
I am facing the same issue and dont have a resolution
Hello @Archish,
I'm sorry for the inconvenience you're experiencing.
I'm using the Logitech C1000E Brio with a MacBook Pro on macOS Sonoma 14.7 (23H124) and Zoom Workplace 6.2.5 (41699) without an issue. I suggest updating both your application and operating system. You can also check out this article for troubleshooting camera issues.
Please let us know if you need further assistance.
