my internet was disconnected during a recording conversion | Community
  • April 2, 2022
  • 33 views
While my computer was still converting a recording of my meeting, my internet got disconnected. Can I still recover my recording? If it is possible, how to do it? I have tried using zTscode to no avail. Can somebody help?
    Bri
    Hi @sutantogf! If you open the Zoom desktop client and click Meetings > Recorded, do you see your recording there?
    @Bri is it possible to get a recording if internet got lost? It is nowhere in recordings.
    Bri
    Hi @Lau_ra , if it was a cloud recording, you should be able to retrieve it. Do you remember how you recorded it?
    sutantogfAuthor
    I'm sorry, but that is expected behavior for local recordings. I would recommend looking into cloud recordings in the future to prevent this from happening. Here is a more detailed explanation of our cloud recording capability: https://support.zoom.us/hc/en-us/articles/203741855-Starting-a-cloud-recording
    Please let me know if you have any additional questions!
    Many thanks zoom community. I got the problem solved not long after my posting in the community space. Please allow me to share what I did.
    FIrst of all my recording was made on my computer. Ideally there should be a file called double_click_to_convert_01 in my zoom folder, which would produce my recording if I double click it. Since the conversion process was interrupted when my internet connection got cut off, this file was not in my zoom folder.
    Finally what I did was, I created another zoom meeting and recorded it in my computer. After the meeting was completed, I did not convert the meeting straight away. Instead I tried to manually recover my recordings from zoom website. Soon after, I noticed double_click_to_convert_01 appeared in my zoom folder, that was previously non existent. After I double click the file, my recordings were saved. So it seems zoom tried to recover all previously not-yet-finished recording
