My camera is zooming out | Community
  • January 12, 2023
  • 8 replies
  • 666 views
Every time I start a call, my laptop camera automatically zooms out. I heard it can be because more than one person is speaking, but how can I disable it?
    Disable video by default
    Sign in to the Zoom mobile app.
    At the bottom of the screen, tap Settings.
    Tap Meetings.
    Enable the Always Turn Off My Video (Android) or Turn Off My Video (iOS) toggle. If the setting is disabled, click the toggle to enable it.
    Regards,
    Will
    Didn't work 😕😕
    When anyone enters in the room, the camera automatically zooms out
    I have the same issue, but it happens randomly even without anyone entering or exiting the room. Pretty annoying
    Were you able to find a solution?  I'm having the same issue and its driving me crazy!
    I found a meeting setting when on a zoom call
    1. Start or join a Zoom meeting or webinar.
    2. Tap the screen to bring up meeting controls.
    3. On the top-left corner, tap Turn On Center Stage to enable the video tracking.
    4. To disable Center Stage video tracking, tap Turn Off Center Stage
    I am glad I am not the only one having this issue. It is very annoying when you are streaming as well
    Have you found a solution?  I am having the same issue and I can't figure it out!
    This is a setting possibly mobile phones only, or possibly just Zoom for android called "Auto Framing".
    To enable or disable this is very tricky.
    This setting is NOT on the menu (general or meetings) but only available when you are on a meeting and on Camera.  If you want to disable it, do it in a meeting, or launch a new meeting even with just you in it. Turn on your camera, or, click the ellipse (...) at the bottom right, and open "background and effects".
    Look around the screen for a floating, semi-transparent, circular icon (sometimes blue) with a camera on it.
    Click that icon, and you will see "Auto Framing".  Turn it off or on whenever you like.
    This feature's placement accessiblity wasn't properly thought of.  They should have a menu item for both camera and audio settings.
    So I don't know what to say
    I tried this but I do not see any floating camera icon.
    Most of these replies are wrong. Open settings in zoom and toggle the option to see video controls. There is a square icon that says center stage. Turn this off.
    There is no square icon. I'm experiencing this annoying thing as well.
    And I'm using Zoom on Lenovo.
    Months later and I still can't find an answer! None of the suggestions work, and I'm tired of my whole desk suddenly appearing in the view when the other person joins the call. I am on my HP laptop.
