Mic not working | Community
Mic not working
  • October 4, 2021
  • 6 views
Dear All,
receive error in zoom app on windows 10pro 64 bits
system does recognize mic but in between the call zoom popups with this error
mic works well on other tools like MS Teams, skype etc... even zoom web app is working fine
we use USB Logitech headset 3.55m jack works but mic with USB headset creates problems
when error comes, zoom freezes the whole system and even audio drives conflicts
the only option then is to restart
    Best answer by Rupert
    Hi @Bharti
    Try adjusting your Signal processing type in Zoom > Settings > Audio > Advanced button > Signal processing.
    Try the different options there.
    See if that helps.
    Rupert
    Rupert
    RupertAnswer
    Hi @Bharti
    See if that helps.
    Rupert
    Experiencing the same issue, my issues started after upgrading to Windows 11, works 100% in other apps and web. But Zoom seems to kill my mic and speakers. Running the zoom tests for mic and speakers works 100%, other parties can hear me while I do the tests, as soon as I close the test, Zoom says it can't detect my mic/speakers again. Weirdly, selecting my speaker again as the output device in Zoom windows app, fixes the speaker/output, but the mic refuses to work. Also requires a restart to get my mic working again after this. Zoom seems to break it for all other apps then. The different signal processing options don't seem to make any difference.
    BhartiAuthor
    Hey @FifoTheHein
    what have you done after that? mic/speaker are working fine now...
    please let me know the solution if have with you then...
    having an issue with the mic on my Mac Pro with zoom. its done this 1-2 other times before but idk why or what triggers it ? other apps like facetime and stuff work and It works on my phone but not on my Mac in the app . my Mac is updated to the most recent software. no app updates. can someone help me please? since apparently a basic account cant even get you friggin customer support unless you upgrade.... never heard of that in my life ..... this app sucks srsly
