Live streaming | Community
Live streaming
  • June 5, 2023
  • 4 replies
  • 55 views
Need help with streaming on facebook and youtube simultaneously
anissat
Hi @Orkids !
You can't live stream to both at the same time directly through Zoom (it's one or the other); however, there are plenty of 3rd party tools that will allow you to do multiple streams (Restream.io and StreamYard are popular tools for regular streaming; Subsplash and other platforms allow multi-platform streaming for religious services).
Bort
HI @Orkids
Unfortunately, this is not currently possible with Zoom, as we can only support 1 live stream at a time. I know there is something being worked on that will expand this capability, but I don't yet have a firm ETA for when this will be available. I will respond back here when I have more info.
Hi Bort, could you please advise if this includes Zoom recording the individual audio and video streams of each participant and have them recorded and then saved on the host's computer (if not in the Zoom Cloud)?
So, as an example, there was two contestants and two hosts, there would be four individual video and four individual audio streams produced.
I am a Trivia Podcast Co-Host and currently the only option seems to be Re-Stream.
This sort of multiple streams (audio and video) would be the sort of thing I'd pay for Zoom Pro for, but otherwise the only other option out there seems to be Restream - and I'd rather stay with Zoom if at all possible.
Please advise if this is something that is under consideration.
Thank you!
Bort
Hi @Blondieboiii
Sorry for not seeing this message earlier.
Currently it is not possible to locally record a meeting and have individual audio/video files for each participant, only individual audio tracks.
Related to restream, as commented above Zoom now has a Live Streaming app that allows the meeting to be streamed to up to 3 services simultaneously.
This app is built by Zoom and free to use: Zoom Live Streaming app
Learn more about how to use this app here
Bort
Hi @Orkids and @anissat
The Zoom App Marketplace has a solution that allows the host to stream to up to 3 different live streaming services! This app is built by Zoom and free to use: Zoom Live Streaming app
I will give it a try and let you guys know if this is possible. Gracias for the post.
You can use multi streaming platforms like Restream, StreamYard, or OneStream Live. they let you broadcast to multiple destinations simultaneously without needing to set up anything too technical. Just connect your Facebook and YouTube accounts, and you’re good to go. It is Good to know, Zoom Also support this.
If you’re working with a brand also planning something more long term, you can explore platforms like VPlayed, Dacast . they support multi streaming and give more control over branding, monetization, and even audience targeting.
