Is it possible to have a secured meeting without a host? | Community
  • September 6, 2021
  • 4 replies
  • 0 views
Is it possible to have a secured meeting without a host?  It seems like this works if the meeting is not secured, but if the meeting is secured the participants gets a "Waiting for host" message.  Is it any way to turn this off?  I want the meeting to run even if the host hasn't started  it, but I still want the meeting to be secured with a passcode.
    Best answer by Bort
    Hi @Himavat
    Yes, it's possible, but the meeting will only be so secure without you there. You can schedule it with the following settings:
    • Passcode - enabled and set
    • Allow participants to join anytime - enabled
    • Waiting Room - disabled
    With those set as such, participants will be able to join, if they have the correct passcode. It would be better to have you present, as that would allow you to use the Waiting Room or Lock Meeting features.
    alex390-orlando
    You can try signing in using the host's zoom account if you know it.
    HimavatAuthor
    Hm... I'm the host, but I want to give the opportunity for my co-workers to attend to a scheduled meeting without my participation, and also without giving away the password for the host login...  And also I want the meeting to be secured with a passcode so that it's not open to anyone.
    Rupert
    You will want to enable "Allow participants to join anytime" when scheduling the meeting:
    https://support.zoom.us/hc/en-us/articles/202828525-Allow-participants-to-join-before-host
    Hope this helps.
    Rupert
    Bort
    BortAnswer
    Hi @Himavat
    HimavatAuthor
    Thanx!  Exactly what I was looking for 🙂
