Idea: BRB Status | Community
Idea: BRB Status
  • October 1, 2021
  • 7 replies
  • 99 views
Regularly, people say "BRB" and then have to write "Ok Back", especially if video is off.  Would be helpful to just have a "BRB" status you can flip on that shows in the participants pane and the video window that you can turn off when you are back.  Bonus points for adding a custom message, like "BRB - 5 min" or "BRB - grabbing a glass of water"
    Best answer by Rupert
    @alexisbrown @jb12 I wonder whether this is also dependent on the account/meeting being enabled for "Non-verbal feedback" or "Meeting reactions"
    Rupert
    Hi @jb12
    The Zoom app itself (your zoom profile) has something like that (Status and Note) for use between Contacts, but I don't think it translates into an actual status seen within a Meeting when in progress.
    That would be a good idea.
    Be sure to submit it at https://zoom.us/feed
    Rupert
    jb12Author
    Ok, will do!  Yeah, I'm specifically referring to an in-meeting status (just for that meeting).  Thanks!
    alexisbrown
    Sounds like you need something similar to this super cool new "I'm away" feature 😎 :   https://twitter.com/Zoom/status/1442890697934135308?ref_src=twsrc%5Egoogle%7Ctwcamp%5Eserp%7Ctwgr%5Etweet
    Rupert
    Loving learning something new everyday in the Community @alexisbrown !
    jb12Author
    Yes that would work I think!  When is that going live? (I don't see it in latest update)
    alexisbrown
    It should be available now in your latest Zoom version 🤔 🤔
    jb12Author
    Don't see it in Version: 5.8.0 (1780)
    alexisbrown
    I am on version 5.8.0 (1324). Does your app say you are on the latest version?
    Rupert
    RupertAnswer
    alexisbrown
