How to get absolute path of zoom.exe? | Community
  • September 10, 2024
  • 36 views
Is the absolute path of Zoom.exe always installed in the following folder?
C:\Users\xxx\AppData \Roaming\Zoom\bin
If not, how to get absolute path of zoom.exe?
New Member
February 20, 2026
That's what Zoom claims, but it's *not* consisent across updates.
I'd like to suggest that Zoom *stop* randomly switching back & forth between creating & deleting then using different app directories (e.g. \bin vs. \bin_00) every other Zoom update/release. I use a shortcut to launch Zoom, and your dumb needless directory path change on every other Update breaks that, forcing me to manually recreate/relink the shortcut.
The Zoom installer created the default-install path as:
C:\Users\<username>\AppData\Roaming\Zoom\*keeps-changing-its-mind*\
i.e.
  C:\Users\<username>\AppData\Roaming\Zoom\bin_00\Zoom.exe
      vs.
  C:\Users\<username>\AppData\Roaming\Zoom\bin\Zoom.exe
It would be better to default-install (which the user can *manually* use) at the "install for all users" \Program Files or \\Program Files (x86) location:
  C:\Program Files (x86)\Zoom\bin\Zoom.exe
and *also* consistently using \bin, not toggle between \bin and \bin_00 for every other update, assuming the same *bug* exists if installed here.
February 23, 2026
%AppData%\Zoom\bin\
New Member
February 23, 2026
Great idea -- if the Zoom app was in the \bin directory. It’s not, at least this month -- it’s currently in the \bin_00 directory.
So %AppData%\Zoom\bin\ doesn’t work (“Windows can’t find …, check spelling and try again”), but %AppData%\Zoom\bin_00 does. For “this month” since Zoom randomly changes (deletes one, creates the other) the \bin vs. \bin_00 tree every few updates, as I reported in my original post. In which case *neither* the \bin nor \bin_00 path works reliably across updates.
