How to export the registrants list | Community
  • August 4, 2022
  • 10 replies
  • 20 views
I scheduled a meeting and it has 130 registrants. I want to capture the name and email address of each registrant so I can import the list into my mass mailing program. How can I export the list?
    Best answer by Bort
    Hi @VolHospice
    Registration reports can be downloaded via the web portal. More info about this process can be found here: https://support.zoom.us/hc/en-us/articles/216378603-Meeting-registration-and-polling-reports
    Bort
    BortAnswer
    Hi @VolHospice
    this is for past meetings, like every other answer; what about registrants for MEETINGS SCHEDULED, future but not past???
    You could use APIs to extract registrants for all future meetings or past. If you are not a developer there is a Zoom app, Salepager, for extracting registrant reports for ALL meetings scheduled.
    Is there a way to download all of the registrants in my account at once or do I have to do it for each individual meeting?
    Hi Guys, also for me is interesting this, I need to export ALL the partecipants of ALL meetings, it is very useful for us to update our CRM with the meetings attended from our online consultants
    Found the problem - some of the worst UX I've ever encountered. There needs to be a download button next to the upload on the page where it's logical to expect it. But maybe the backend is a little too inflexible. Who knows? Not a pleasant half hour trying to figure this out. But thanks for the solution.
    This post has been deleted.
    the only option I have is 😥
    There is no button for "export" only "import" or "edit" when you are on the "Registration" tab.
    Somehow I was able to find it in Reports > Usage Reports > Meeting ~'Meeting Report' section, we need to select the "To Date" as the date of our scheduled meeting & click search. Then this will show that meeting description along with generate button. Click this and it should take you to the 'Report Queue' tab. Here, after sometime your will see the download button.
    THANK YOU!  As others had mentioned it WAS under the Registration tab of one's meeting.  I don't know whose bright idea it was to remove it from the MOST LOGICAL LOCATION and then bury at Reports > Usage Reports > Meeting, but I'm sure they make a bunch more money than I do.
    I am in the same boat that Khh is.  I need to export the list of registrants for a future Meeting and these steps do not help.  I need it to be able to send them a workbook and it is crazy that I need to copy them one by one.
    Hey guys I found the solution
    On left bar there is a a report tab open it -> click on meeting -> select your meeting -> Click Generate -> Download
    Hope this helps
    This is a MUCH better solution...in fact this should be THE solution to the OP.  THANK YOU!
    A staff member and I were able to figure it out by going to
    1. the "Reports" section on the right
    2. click "meeting"
    3. Find the previous meeting in with date of the meeting
    4. At the top click "Report Que"
    5. Then "download" at the left
    6. Celebrate
    Godspeed fellow Zoomers.
