How to copy and paste 100+ in drop down list registration question | Community
  • March 17, 2026
  • 10 views
I would like to use copy and paste for a selection of 150 items in the registration field. Is this possible?
    If the field supports bulk input, you can usually copy-paste a list of items (often separated by commas or line breaks). However, in many systems, registration fields only accept one entry at a time, which means bulk pasting won’t work directly.
    If you’re dealing with around 150 items, you might want to check if there’s:
    • A CSV import/upload option
    • A bulk entry feature
    • Or an API/integration to add them programmatically
    Would you mind sharing which platform or tool you’re using? That way I can give a more precise answer
    TMPJAuthor
    I am using Zoom Workplace Business. Setting up a meeting with registration requirements. Questions to include 150 items in the drop-down using copy/paste in Excel or Word document.
