How to Change Date Format to dd/mm/yyyy | Community
  • February 28, 2022
  • 17 replies
  • 4 views
Living in Australia, we use a Date Format of dd/mm/yyyy but when I try to change the Date Format on my profile, there is no such option. I know that Zoom is very specific to the USA but surely they would provide a way to set the Date Format since dd/mm/yyyy is commonly used in many other parts of the world, not just Australia. Any help would be appreciated.
    Oops. I just spotted the "scroll bar" and used it to display all the other Date Formats including dd/mm/yyyy. Problem solved.
    What scroll bar where? I have changed the date format in my profile but this has no impact on the Scheduling a meeting option.  It stays wuth the American format.  It didnt use to do this but for some reason it has begun to happen for all sheduled meetings
    Like Ajp2 I have noticed that the scheduling has switched to US date format (very confusing for us non-Yanks).
    My profile has the correct settings so I can only assume that one of the recent upgrades has "improved things worse".
    How do we feed back to Zoom?
    Same problem. Why has the meeting scheduling not saved the UK date format????
    Also can you re-instate the 15 min meeting time options - much easier than over writing.
    Same again. It is possible to set the date format to dd/mm/yyyy and time to 24 hour format in zoom profile. However, schedule in the Windows desktop app completely ignores this and displays dates and times in US format - very confusing for everyone not in the US.
    Same here in the Netherlands. I don't see a possibility to change the date format in the Windows app. I hope this will be fixed in a update: for example, that the adjustments in Zoom profile also work through in the Windows app.
    I have had a reply from Zoom and they tried to identify the problem by me sending screen shots.  Thay have now stated that there is no solution to this problem if you are using the app which I am.  Changinf the profiloe does not affect the app.  Maybe you might like to contact them and air your views on this
    Just had a contact from Ajp2 saying that they werer told that the date format for the UK will not be changed. Why is it then that when I installed zoom over 2 years ago the date format was UK compatible and in the last 2 months it has changed to a firm US format. You therefore have the expertise to offer the UK format but obviously you're not bothered about serving the UK community. Why?
    The scroll menu with date options is to be found in the profile menue on the left side.
    That 's true of course. The point is that when I change the settings in the profile menu, in the app on the Windows PC the US way of writing the date doesn't change. So in my profile the way of noting the date is different from the app on the PC. (The same is with the time zone, the changes in the profile don't effect the choices in the app on the PC.)
    This is highly unsatisfactory and very disorienting when zoom suddenly overrode my preferences for date formatting after an update. it may well be a deal-breaker for me!
    Zoom quality control - please lift your game!
    You can easily change the day/month/year in your personal PROFILE 😀.
    Cmorga24. Please read the replies to this thread. Changing the date format in zoom profile has no effect on its presentation in the application.
    Cmorga24 this reply is not helpful! I HAVE changed the format in my personal profile but this has no impact on the date format on the desktop app used for scheduling meetings. This is what many users are complaining about. The last thing we need is unnecessary confusion being created about the date of a meeting !!!!
    agree, seeing the same thing now after a forced update. very poor.
