How should I subscript if I want to run meetings and webinars both? | Community
  • October 27, 2021
  • 0 views
I am planning to run 8 meetings and 3 webinars per week.
How should I select the plans?
Thank you for your help!
Miki
    Best answer by Rupert
    Hi @Mikirinne
    It depends on the size of your Meetings and Webinars, and whether any need to run concurrently.
    If your Meetings are under 100 Participants, and your Webinars are under 500 Attendees, and nothing will run concurrently, then all you will need is a Pro license with a Webinar 500 Add-On.
    https://zoom.us/pricing and https://zoom.us/pricing/webinar
    If you need something more complex, post back here with more detail, for more guidance.
    Hope this helps.
    Rupert
    http://hybridevent.pro/
    Rupert
    RupertAnswer
    Hi @Mikirinne
    Hope this helps.
    Rupert
    MikirinneAuthor
    Thanks Rupert,
    I see, I didn't think 'Zoom video webinar' is add-on.
    Thank you!
