Host has another meeting in progress | Community
  • August 16, 2021
  • 26 replies
  • 50 views
I was the only host and had the settings so the participants could join at any time. I had only 2 participants currently in the meeting and waiting for a third. The third participant received the message that the host had another meeting in progress.  The third participant tried several times but was never able to join.
    Ohkawa
    Hi, SFarquharson
    If you have more than one meeting scheduled, 3rd participant may get such a message if he join with the wrong meeting ID.
    It would be better to invite a third participant by inviting the participant
    I have the same problem.  Only one meeting is scheduled, everyone has the correct meeting ID and they still get this message that I (the host)  am in another meeting.  I have been using Zoom for years and this problem has just started over the past two months.  Very frustrating.
    Same issue here. 😞
    Nafi
    Community Champion | Partner
    August 17, 2021
    Hi
    Please make sure you invite third participants to the correct meeting id for this kind of issue.
    Hope it helps! please like and mark this as solution so whenever someone has the same question this content will help.
    This is not helpful.  It's a chronic problem when I'm invited to a mtg and I get "host....another mtg"  I guess I need to switch to google or facebook.
    The problem is not on your end. It's on the Host's end. They need to SIGN OUT after they Leave Meeting for All. There is a dropdown menu under the icon that is their name...on my iMac it's the upper right hand corner with my initial...to SIGN OUT. This has worked for me for the past two months. So far so goo.
    I will try before my next meeting.  It is so frustrating when I hear this.  For me it has been since 3 months in a row and no one seems to be able to say why it happens.
    Fingers crossed.
    None of the responses helped with this issue.  I am having the same issue and have run through all the checklists making sure everything is in order.  Parties are still getting the same message of  "host in another meeting".  It is the ONLY meeting I had set and participants were all invited to the correct (only one) meeting.   Can you please help with a relevant answer?  Thank you.
    I’ve found this means the host is logged into two devices at once in their zoom account. They need to close the zoom app on one device.
    for example if I as a host was on zoom via my phone and then left the meeting but didn’t actually quit the app, and then later try to host a meeting on my computer, attendees will get this message. All I need to do is truly quit zoom app on my iphone or iPad and then the attendees will be able to access the meeting I’m hosting on my computer.
    of course the issue is that the host doesn’t know that the attendees are getting this error message. Aside from lack of attendees or someone texting/calling  them to let them know, the host will not know there’s an issue.
    I had a simular problem. But in my car a 3. member joined the meeting, became the role as host and me and my session was stopped. I joined the new meeting but other people couldn't. I invited others to the new meeting by mail. The inviting was with the same meeting id and code as the original meeting. But only the new invited members could join. The same thing happened before but only when there was an other meeting scheduled later. So, in future I'll only plan one meeting.
    I mein in my case ...
    I've had this problem a few times as well, and I was not logged into two devices at once.  Very frustrating and embarrassing!
    If the app is open at all on one device (I.e. you haven’t swiped up on the phone even though you’re not in a meeting and truly closed all the way out of the app) and you try to conduct a meeting on another device it considers you’re logged in two places at once for hosting purposes
    I also logged into my Zoom account and signed out of all devices, still the issue persists
    and it still persists - very unsatisfactory and embarassing
    What worked for me is ticking the "Use my personal meeting ID" box. No issues since
    This worked for me!
    Thank you!
    I'm surprised and disappointed that a zoom rep has not addressed this issue. Previous posts are quite clear
    as to how embarrassing, inefficient and downright unhelpful this issue is. I will try ticking  "Use my personal meeting ID" box
    We have the same issue intermittently, despite applying suggested fixes.  Makes my yoga studio look really bad.  Please make this a priority, Zoom!
