Full Screen participant list on ipad | Community
  • February 23, 2023
  • 4 replies
  • 49 views
I want to use an ipad for a presenter to use on stage but want to view the participant list full screen not the little thumbnail to the right.  How can i accomplish this?
    Start or join a meeting. By default, the Zoom mobile app displays the Active Speaker View.
    Swipe left from the active speaker view to switch to Gallery View.
    Swipe right to the first screen to switch back to active speaker view.
    I want this feature too.  I want Ipad to work like the phones do.  On a phone the participantist is full screen.  We use this to look for participants with hands raised.  The gallery view (as suggested above) makes the names too small to read (we use an Ipad Mini on a stage podium).
    We recently ran into the same issue with our new Ipad tablet (we didn't know it would do this).. the only work around I've found that might work is use the split screen option. Select the 3 dots at the top, select Split Screen, this will make half the screen the length of the tablet for your participants and the other half you could use your notes or other reference information if needed.
    Hope this helps.
    Only works on iPads with multiple screen view. So it has to be a PRO model.
