Force end Zoom Meeting after scheduled time | Community
  • November 1, 2021
  • 5 replies
  • 1 view
Is it possible to force end a meeting after a certain amount of time?
So for example if a meeting is scheduled to last an hour is it possible to have a countdown and cut them off?
Thanks
Paul
    Bort
    Unfortunately, that is not possible.
    GreenMeeting_ca
    Human intervention required.
    ChrisO
    Participant
    Participant
    November 1, 2021
    As the others said there is no way to force end a meeting. You can however put time limits on breakout rooms which will automatically close them. Might help your situation might not. You can also send "end meeting" via API if you know how to set a delay for the call and have the ability to use APIs.
    Funnily, it seems we now have an opposite problem in 2024. People report that with a scheduled meeting the meeting forcefully ends with the planned end time!
    Please tell. I give online Counseling session. I want to automatically end meeting after the set custom meeting time is over. anyone help pls
